Results 1 to 5 of 5
Thread: Ribbon PCI riser cards w/ 2 slots???
    Mar 2002
    Seattle WA
    Hello...
    I don't know which riser to buy for my Epia motherboard. I know I need a card that goes from one PCI slot to two... but I also need one that is on a ribbon mount or cable mount because my case is so tight on space. (Basically I need it to fit parallel, on top of the motherboard. mini-itx.com sells circuit board ones, but they face the wrong way)
    I've found a couple here:
    http://www.mycableshop.com/2nd_Cat/R...RiserCards.htm
    but I have no idea which is compatable. 32 bit? 64bit?? what does that mean?? 5 volt? 3.3 volt? I don't know what that means either! Any assistance is appriciated...
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    The EPIA is a 32 bit PCI slot and I thought that you need a speacial on for the 1 to 2 PCI slots?
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Maximum Bitrate 00CericaRuss's Avatar
    Jul 2002
    San Rafael, CA, USA
    Mar 2002
    Seattle WA
    Hmmm... This still does not answer my question I'm afraid. I need a pci extender which goes from ONE pci slot to TWO. And it has to be flexible, so I can orient it a couple different ways. I think this is what I'm looking for: http://www.mycableshop.com/sku/RSRPCI2C.htm but I'm a bit scared by the picture. It looks like this does not have nearly enough wires/gold contacts to be the right thing I need.
    I didn't see anything on the buildyourserver.com site, unless it would be easisest to use a PCIRX4-FLEX-A5 Right angle PCI 32 bit Flexible Extender in conjunction with a regular one to two pci adapter. http://www.mini-itx.com/store/default.asp?c=8#p50
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    Quote Originally Posted by wompser
    that doesnt look like what you need... that just looks like it turns two pci slots into...two pci slots. not one into two..
    rebuilding carpc... kinda..
  1. which pci riser sive for m10000?
    By [H]Bugster in forum General Hardware Discussion
    Last Post: 11-02-2004, 05:16 PM
  2. PCI riser cards
    By Zensay in forum General Hardware Discussion
    Last Post: 10-19-2003, 09:52 AM
  3. PCI card riser card
    By allenruble in forum Classified Archive
    Last Post: 11-25-2001, 08:51 AM
  4. New powersupply! Question about PCI riser card.
    By jssaggie in forum Power Supplies
    Last Post: 08-30-2001, 09:34 AM
  5. adding pci slots?
    By etrik in forum General Hardware Discussion
    Last Post: 04-04-2001, 08:28 PM
