Results 1 to 10 of 20
Thread: WD Hardrive problem?
    Low Bitrate Crav4Speed's Avatar
    Nov 2003
    New York City
    I just got my WD 120GB harddrive yesterday... loaded XP Pro onto it and it worked great. Today, I tried booting up my M10k and the harddrive is making a noise like a cd player that can't find the beginning of a track and it won't boot up or anything. Is there a problem with the harddrive or do you think it might be the ribbon cable? Do you guys think I need to return it?
    Maximum Bitrate 00CericaRuss's Avatar
    Jul 2002
    San Rafael, CA, USA
    sounds like you don't have enough power to spin it up.. what kind of psu you using?
    i had the same problem on my m9000 off a pw70 trying to use my bus powered usb drive
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    I had the same issue with using the stock power supply with my cheapo castronic case. As soon as I pumped up the voltage, its all good. It is definately just power related by the description.
    2005 Ford Focus ST
    Oct 2003
    Download and run this ::This::
    It is a program called gwscan written for Gateway from WD. What you need to do is 1 of 2 thing:
    1.) either create a windows 98 boot disc and copy these files over to it and overwrite anything on it. Then reboot and boot to the disc, if it takes you to an A:\> then just type GWSCAN and press enter. When at the main menu just choose the option to Run Extended test. It will give you either a pass a fail or will let you repair the drive.
    2.) Format a 3 floppy in windows xp and choose the option to create MS-DOS boot disc. When the format is done go into the floppy goto Edit -> Select All then hit delete and delete everything. That writes the master boot record to the floppy so its bootable. When done w/ that extract the file that you downloaded to that particular disc and again boot to the disc and run gwscan from the A:\> prompt. If it fails you have a bad drive definately
    HOWEVER DO NOT CHOOSE TO WRITE ZEROS TO THE DRIVE BECAUSE IT WILL DESTROY ALL DATA ON THE HDD AND WRITE A ZERO TO EVERY SECTOR TO THE DRIVE
    If you have any questions feel free to PM me!
    New CarPC on the way again I think. I miss my old one!!!
    Oct 2003
    Oh ya by the way, I agree w/ the power supply issue too. but if you want to test the hdd, check my notes above!!
    Jul 2002
    San Rafael, CA, USA
    that program won't be possible on his m10000 since it can't even spin up
    Oct 2003
    Yes it will... since you need to load it from a floppy disc into memory. trust me on this!!! If you can boot up to a floppy disc then he should be able to run this, as long as the hdd is being recognized in the BIOS. I would hook up floppy and test it out!! As I stated I agree w/ the PSU issue but if you want to test the HDD there are some directions. If he can't get into windows on this sytem thats fine do it from another to ge this done if need be!!!
    Jul 2002
    San Rafael, CA, USA
    imo, it sounds like it's not spinning up on the m10k, if no spin up, no bios detection
    Dec 2003
    Portland, OR
    That was my issue...it is not recognised even. Power supply cured mine real fast. to be sure, just plug in a ATX power supply and recheck it. I know it will work
    2005 Ford Focus ST
    Jul 2002
    San Rafael, CA, USA
    woohoo i guess that's why they don't pay me the big bucks
  1. Hard audio quality problem: Noise / Ground loop?
    By Burat in forum General Hardware Discussion
    Last Post: 09-09-2004, 07:08 AM
  2. psone screen video problem
    By WILD9 in forum ME Archive
    Last Post: 11-27-2003, 01:38 AM
  3. cordless phone problem
    By jstrain in forum Off Topic
    Last Post: 06-24-2003, 12:09 PM
  4. Replies: 8
    Last Post: 12-31-2002, 12:37 PM
  5. Annoying problem
    By c-dawg in forum General Hardware Discussion
    Last Post: 07-22-2002, 09:19 PM
