300ma is .3 amps
it is probably fuesed internally already. crack the case (well, not literally) and see if you can spot one.
if not, get a fuse with a voltage rating that is higher than the max voltage you'll put on the input and current rating larger than the max current.
so maybe 25v .5a would be good.
LinkBack URL
About LinkBacks
