Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 69
Thread: What kind of USB Wifi adapter do you use?
  1. #21
    Jan 2003
    Ruston, LA
    Quote Originally Posted by LESLIEx317537
    Before I close it up.
    No strain relief ! Bad
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  2. #22
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    I used 5 min epoxy. Look closley, but good looking out.
    I'm also not planning on tugging it.
    Tested it, works alot better.
    I am a rc plane modeler. Always have many types of glue.
  3. #23
    Jan 2003
    Ruston, LA
    I try
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  4. #24
    Constant Bitrate Vineet Singh's Avatar
    Jul 2003
    Naperville IL
    Quote Originally Posted by frodobaggins
    Yea, put a ziptie around the wire before it exits the casing
    Whatever you do, don't buy the USB D-link DWL-120. There are like five billion revisions (I have rev 2), five different, un-updated drivers (one doesn't support XP), and mine supposedly does, but freezes any computer I use it in after 1-30 min.
    Garbage. Too bad it took so long for me to get to use it, otherwise I'd be getting a linksys as an exchange. I don't have any PCMCIA ports left, otherwise I'd use the Orinoco Silver I have (love em!)
    91 Stealth RT/TT
    CarPuter: Inspiron 5150 P4 3.0ghz; Built-in WiFi; Deluo GPS; Radio Shark; OBD1; Nostromo Speedpad
    Audio: Audigy 2 NX; Clarion 500.5 amp; 100.2 center channel amp; Kicker Solo-baric L7 10" Sub
    Display: Lilliput 7" Touchscreen
  5. #25
    Jan 2002
    Long Island, NY
    My Epoxy is stronger than a ziptie, and the ziptie can slip if you pull on it real tight, and will still move if you push the wire in.
    I had a USB D-Link-120 in my v1.0 setup. It was the 2nd revision or something...I got it on eBay for cheap and used it for 1 1/2 years in my CarPC and then sold it about a month ago on eBay. It seemed to work fine with me, but my friend did recently by a D-Link newer 120 unit and it was smaller and didn't work well at all with XP. It kept connecting and disconnecting.
    So far the USB G Linksys has been OK. It's not as strong as the PCMCIA Linksys G card but for USB, I'm not gonna complain.
    I was about to get the NetGear USB G, but bought the Linksys instead. I have heard good things about NetGear lately.
  6. #26
    Jul 2003
    Naperville IL
    I had a USB D-Link-120 in my v1.0 setup. ... It seemed to work fine with me, but my friend did recently by a D-Link newer 120 unit and it was smaller and didn't work well at all with XP. It kept connecting and disconnecting.
    Yea, it will disconnect for around 3 seconds. Makes it hard to VNC into when the mouse stops responding for 3 seconds ever 30 seconds or so. When it doesn't respond for more than 3 seconds, that means the d-link just crashed the pc and it's rebooting
    Nice car! I had a 2003 WRX with an FP turbo on it, and some other minor mods. The brakes suck on that car (actually, just the ABS is a supersensitive grandma ninny system), and it got totalled. A honda changed lanes w/o looking and hit my front corner (I had just put a JDM STI grill on . I went to full brakes and avoidance, minimal brake impact/feel, the rear end lifted and lost traction, overcorrected 2 times, flew across intersection of highway, landed in front of oncoming semi.
    Got t-boned by a minivan passing the "slow semi" (the semi was slowing down to avoid hitting me full force, full air horns). The lady in the minivan didn't see me hop out into her lane instead of the semis. Her husband was yelling at her about me, and I saw her with her head turned towards him until the last 20-30 feet (at 50mph+). There is an investigation through the NHTSA for it (the brakes), I don't know if the STI model is affected or included.
    The car is very well built (safety wise... rustwise, dunno).
    91 Stealth RT/TT
  7. #27
    Jan 2002
    Long Island, NY
    SOrry to hear that!
    The STi has 4 piston Brembo calipers on the front and 2 piston is the rear I think.
    They are like 13 inches almost.
    Super sport ABS. My brakes rock!
    Look at the size:
  8. #28
    FLAC bosstone74's Avatar
    May 2002
    Japan, Oregon
    I'm glad this whole topic has been brought up, I've been looking at getting a wireless setup for some time now...and since I am taking back the "Roomba" (the automatic vacuum) to Best Buy, I'll have about $300 to blow. I know I won't beable to get everything I need at best buy,(big *** antenas) but what should I get. I have 3 comps in the apt. 2 desk tops and one laptop. I'd like to go with "G" for the speed, but I'd also like to keep my desktops and PS2 hardwired too. So I'll actually be only connecting to 2 comps wirelessly.
    I've always been a fan of d-links gear. I would basically like to have a system in which I could automatically "sync" my files from my apt. to my car. It's also a bit of distance with a bit on concrete in between. (would a big *** antenna help?)
    thanks for any advice folks!
    BossTone74
  9. #29
    Jan 2002
    Long Island, NY
    I would stick with one brand for ease of setup and compatibilty.
    I would go with Linksys or NetGear. I decided to go with Linksys.
    Get a regular router with no wireless built in $75 and then buy a small switch $50 and a wireless access point $100. That's 3 devices to get the network backbone up. You will have a switch for wired connections and a WAP for wireless connections. You router will then assign IP's and also route the Internet.
    Then get Wireless client cards for each wireless connection and ethernet cards for the hardwired connections.
    With this setup, you can always change just the WAP and change the format from say G to anything they change in the future.
    You can also just spend 125 buks and get the all in one Wireless router/switch/wap but I don't like all in 1 devices and my way you can reposition the wap anywhere you need as long as you run a ethernet line.
    Yes a huge antenna will help.
    If you get one on both ends it will be better.
    What was wrong with the Roomba vac?
  10. #30
    Jul 2003
    Naperville IL
    Same question here, I got hardwood floors downstairs and dogs... wife loves the christmas roomba present (she calls it Rosie from the Jetsons). Got one for my dad too, and he likes it a lot.
    91 Stealth RT/TT
  1. usb to pci adapter ?
    By finnman925 in forum General Hardware Discussion
    Last Post: 08-20-2006, 08:06 AM
  2. USB 802.11b adapter with external antenna anyone?
    By cyjad in forum General Hardware Discussion
    Last Post: 12-03-2003, 09:07 AM
  3. Has anyone tried a usb printer adapter for a parallel LCD?
    By ShinkunoNamida in forum LCD/Display
    Last Post: 02-21-2003, 03:48 AM
  4. WTB: PCI or USB Wireless LAN adapter CHEAP!
    By bombboyer in forum Classified Archive
    Last Post: 12-21-2002, 10:44 PM
  5. USB Sound Adapter
    By allenruble in forum Classified Archive
    Last Post: 12-09-2001, 07:05 AM
