Results 1 to 10 of 20
Thread: Help finding a 54g PCI wifi card for Procase'd carputer
    Variable Bitrate NJay's Avatar
    Mar 2003
    UK
    I currently have the carpc linked up to my house wifi and that works fine but ultimately since the house wifi system is actually 54g (and netsumbler don't work with usb wifi devices ), I'd like to get a 54g pci card that has a detachable antenna for the carpc.
    I do already have a spare belkin 54g PCI card (F5D7000uk) but here's the problem.
    The CarPC is in a Procase 3677 so whilst the Eden800 works fine with this card the width of the Belkin Wifi PCB (already removed the metal plate) when sitting in the PCI slot is 4mm higher than the rest of the casing and hence the lid don't fit I've looked and belkin are very miserly with the pcb as there is no way of shaving the pcb down so that it fits
    I have tried a ribbon pci extender but there is just not enough room inside the case to orientate the pci card.
    So the question is (as trying to get this info out of retaliers tend to get met with an expression that I've grown another head) any of you guys know of a
    54g PCI card that has a PCB of 40mm or less width excluding the pci edge connector?
    Here's the belkin one which you can seen the green pcb area on
    Cheers.
    Variable Bitrate Batmanatthenewb's Avatar
    Sep 2003
    Newark, Ohio
    NJay,
    Personally don't know of a smaller card. However, I was having same issue with my Version 1 system. Case was only 3 inches tall and cards were taller. I opted for a pci riser which came back over the motherboard (as opposed to the ones that go and cover the pci slots)from Barada (http://www.barada.ca/eng/index.htm), and a data chute. Card is tall. But since there was no external connection, it didn't matter in my case. With the Data Chute (by Antec) I can run any pcmcia card on my system. This is great for using any wifi, wired nic, pcmcia scanners, pcmcia card readers, etc.... Basically I now have a verychangeable system without taking anything apart. Push a button pop one card out , and put another in.
    Hope this gives you an alternative, if you cant find a smaller card.
    Batman
    Batman@TheNewBatcave.com
    AMD XP 2000, 1gig PC2700, 80gig 7200RPM HD, DVD CD/RW, ATI All in Wonder 8500DV w/remote, DataChute, IRDA, Wireless 802.11b, cell modem, Lilliput 7" VGA TS, XP Pro, GPS w/Routis
    www.samshomepage.net
    www.Cars-N-Computers.com
    Maximum Bitrate churnopol's Avatar
    Apr 2003
    Delaware!!!
    Some eshop links i've had tucked away
    the first link has the worlds longest pci relocator card. The cables can easily be extended upto 24 inches (i think)
    Falcon cr53 w/ via epia m10000. Nokia 3650 blutooth phone.
    Better than winamp. Click here for qcd player.
    Apr 2003
    Delaware!!!
    or you may want to use a pcmcia to pci adapter
    http://cgi.ebay.com/ws/eBayISAPI.dll...category=41993
    and use a 54g pcmcia pc card
    Mar 2003
    UK
    Cheers foir the suggestions
    Yep, already have a 54G PCMCIA card as that resided in my laptop. However they are wider than the PCB on the desktop card so the PCMCIA->PCI adaptor would be even wider than that.
    Here's the case with the lid off. As you can see its not the length of the PC flex riser that I have that's the problem but that there just isn't any space where I can place the pci card other than upright in the pci slot
    Nov 2003
    Las Vegas/Henderson, NV
    Mar 2003
    UK
    Thanks,
    but that dlink one appears to be a PCMCIA card mounted onto a PCI card. Consequently thats going to be 53mm wide and I'm looking for something less than 40mm
    Keep looking though
    Nov 2003
    Njay, I'm going to have to guess that your SOL. Somethin that small is only compact flash which means you would need a PCI adapter, the smallest one I found looks too big http://www.axiontech.com/prdt.php?src=PW&item=58022
    Besides that, Compact Flash cards only support 802.11b.
    Mar 2003
    UK
    I think you might be right.
    Its frustrating as I know that there are 11mps ones out there as this one from the UK e-tailer I use has a smaller width PCB.
    Oh well the search continues
    Apr 2003
    Delaware!!!
    or you can forget about the pci card all to gether and get the 802.11g usb adapter
    http://www.amazon.com/exec/obidos/tg...38566?v=glance
  1. need PCI nvidia video card with Conexant TV chip
    By Onyx in forum General Hardware Discussion
    Last Post: 11-12-2003, 04:14 PM
  2. PCI Graphics card with TV Tuner in UK?
    By phoTToniq in forum General Hardware Discussion
    Last Post: 03-21-2003, 10:38 AM
  3. PCI card riser card
    By allenruble in forum Classified Archive
    Last Post: 11-25-2001, 08:51 AM
  4. New powersupply! Question about PCI riser card.
    By jssaggie in forum Power Supplies
    Last Post: 08-30-2001, 09:34 AM
  5. 2 db-9 serial ports PCI and credit card remote
    By moahdib in forum Classified Archive
    Last Post: 07-25-2001, 12:41 AM
