Results 1 to 3 of 3
Thread: epia 5000 & pw-60b issue
    Jun 2003
    Kansas City, MO
    Hey guys I have an EPIA 5000 mobo that is being powered by a PW-60B I bought from a friend. The problem is that the motherboard will not power up while using this power supply but when it is on my 300watt power supply it work s fine and will power up like expected. The PW-60B though will power up the power on LED and any hard drive or cd-rom that is hooked into it.
    Is this motherboard and powersupply combonation not going to work or am I not doing something right maybe?
    Philip Plante
    my projects:
    idgn.org | idgnonline.net | contrastsolutions.net
    Variable Bitrate NJay's Avatar
    Mar 2003
    UK
    Sounds like not enough power.
    Are you using a 3.5inch harddrive or full size CD rom drive as I didn't think the PW-60 had enough power to run these. Try disconnecting them (including the IDE cables) and then boot it up.
    Jun 2003
    Kansas City, MO
    Well even with just the mobo and psu hooked up together I still get nothing.
    Philip Plante
    my projects:
  1. PW 120 HDD Power up Issue
    By RX7FDTT in forum Power Supplies
    Last Post: 01-12-2004, 11:20 AM
  2. Sproggy 2.5 PSU. Can i run Via epia 5000?
    By tomis_86 in forum Power Supplies
    Last Post: 11-19-2003, 11:18 AM
  3. Epia 5000 Overclocking
    By Banzai in forum General Hardware Discussion
    Last Post: 10-22-2003, 06:32 AM
  4. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 08:48 PM
