Are you sure it takes 12V in? Most take 5V in at 2 or 2.5A...Regardless of the input you could get 12V or 5V from your PSU in the computer. Just run the wires.
I need a USB hub, but I do not want to put it though the invertor. Is threre anything on the market with 12V connector, so I can hook it directly to the car power.
like this 5v 2.6A usb hub?
http://cgi.ebay.com/ws/eBayISAPI.dll...category=41911
Car: 2000 Audi A4 Avant 1.8t
Carputer 2.0: removed. Back to stock.
Nope not like that one. That has a ac adapter for power. Need something that would convert 12vdc car battery to 5vdc and 2+ amps.Originally Posted by brrman
Like this one?
http://www.seidioonline.com/ProductD...uctCode=SUAT91
Originally Posted by Defiler
No amp rating? I wonder what it put out? Anymore out there?
Here's what I installed last weekend. Doesn't provide a ton of power-uses a second usb port for additional power. Easy install and solved my problems that I had with unpowered hub.Originally Posted by blaster
http://shop.store.yahoo.com/pcsound/849065.html
http://www.staples.com/Catalog/Brows...12751+++++++++
Check out this one:Originally Posted by blaster
http://www.monoprices.com/products/p...seq=1&format=2
It has a wall-wart power supply that supplies the hub with 5v DC @ 2.6a. You could wire it to a molex connector and plug it into your PC power supply.
So far:
M10000 Nehemiah, 1Gb RAM, Opus 90w PS, Buffalo Tech WLI2-USB2-G54, 160 Gb HDD, GlobalSat BU-353 GPS, iGuidance, Zippy EL-610, Panasonic CW8123B Slim Slot CDRW/DVD, 10" Lilliput, Sony XA-300, Sony CDX-MP30 Head, OBD-II
Looking for power from a 12VDC power to 5VDC with something >2 amps. THERE IS NO SOURCE FOR 120VAC!!!Originally Posted by tom2112
