Results 1 to 10 of 10
Thread: 2.5 to 3.5 hdd adapter
    Low Bitrate LudeAtude's Avatar
    Jan 2004
    Question 2.5 to 3.5 hdd adapter
    i have a m10000 nehemia mobo, 20 gb laptop hd. just got my adapter to connect the two. well my ide cable has one of the pins blacked out. and on my adapter it has a pin in that location. what am i supposed to do. did i get the right adapter? do i bend it over? thanks.
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    drill a hole in the cable connector to make it fit, the pin is probly not used and not supposed to be there
    Constant Bitrate Big Zack's Avatar
    Oct 2003
    break it off
    You got the right adapter - they all come with that pin. I use those adapters all the time at work to recover data from dead laptop drives with no problem. Trying to drill out the 3.5 side is too much of a pain. Needle nose pliers and a couple of bends back and forth should snap that thing right off.
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    I used an old 40-conductor IDE Cable...they dont have the pin blacked out
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
    Maximum Bitrate orangewhip's Avatar
    Apr 2001
    Surrey, B.C. Canada
    Quote Originally Posted by wizardPC
    Or you can go to an electronics shop and buy a new IDE end for it, most of them don't have that hole filled in. That is what I did, and too boot, you can customize the length of the cable simply by cutting it down and applying the new IDE end. Was only like $1.49 Canadian.
    OrangeWhip? OrangeWhip? 3 OrangeWhips!!
    www.whipflash.com
    Finally a new Avatar!
    Dec 2003
    Quote Originally Posted by Big Zack
    Which side are you supposed to break off? Also, how well are those converters supposed to fit on the laptop HD pins? Mine doesnt go down all the way. The connection is pretty loose. It can easily fall off. Should I be pushing the converter down harder? Im afraid I might bend the pins. I have a Hitachi Travelstar 60GB.
    Dec 2003
    Question super old thread bump
    Constant Bitrate RPI Geek's Avatar
    Oct 2004
    Schenectady, NY
    They meant to break off the appropriate pin from the adapter, not the hard drive. The adapter has a small end that fits into the laptop drive that you can't break anything off from. The other end of the adapter has 40 (?) pins sticking out of it and you just need to break off the one that will let the adapter fit onto the ribbon cable.
    Old plans out the window because of an accident .
    Have: M1-ATX, EPIA M10000, 256MB, 60GB 2.5", slim slot load DVD
    Need: Time, HU integration, ideas for Lilli
    Dec 2003
    Ok i get it. What about the fitting problem? Is this common?
    Oct 2004
    Schenectady, NY
    I don't know about that... The adapter that I have fits loosely for the first 2/3 of the way on, the last 1/3 is very tight - I mean I was afraid that I'd break it the first time I put it on, after that it went smoothly.
    Is there maybe something wedged in one of the holes that's keeping it from fitting in the rest of the way or does the adapter just not go on any farther for every single pin? Try putting it on and rocking it back and forth the long way to see if one end goes on easier than the other.
    If neither of these thoughts helps, then I'd suggest waiting to hear back from other people who've used these adapters to see if they've had similar problems. You could always try just using the adapter as-is or taping it in place, but that's a really sketchy way to do it.
  1. Alpine AiNet aux input adapter SOLUTION!!!
    By aydensdad in forum General Hardware Discussion
    Last Post: 08-16-2011, 05:30 AM
  2. Hard Drives - 3.5 vs 2.5
    By RobbieIG in forum General Hardware Discussion
    Last Post: 08-20-2003, 09:57 PM
  3. cheapest place to get an laptop hdd adapter?
    By whoojong in forum General Hardware Discussion
    Last Post: 01-27-2003, 12:19 PM
  4. Pin out for 2.5 HDD to 3.5 MB Connector
    By Droopy in forum General Hardware Discussion
    Last Post: 12-19-1999, 11:18 PM
  5. 2.5" to 3.5" convertor
    By GrahamS in forum General Hardware Discussion
    Last Post: 11-28-1999, 09:12 AM
