Results 1 to 8 of 8
Thread: Testing: WD 160gig HD in -20 Celsius
    Newbie MiniRX7's Avatar
    Aug 2003
    Toronto
    Well i finally got the balls and left my X-BOX with a WD 160gig HD in my car all day today.. Temperature outside is like -20celsius (canada).
    I am going out there now to turn the x-box on to findout what happens.
    I will keep you posted.
    2k3 Max SE 6spd
    Temp setup:
    7" indash screen/Xbox running XBMC
    Carputer coming soon
    My 2003 Maxima
    May 2003
    Thats -4 F... i hope your drive didn't freeze or the liquid bearing inside.
    [ L ] ive. [ D ] ream. [ C ] reate.
    Aug 2003
    Toronto
    Okay back from the drive..
    My 7" LCD screen was frozen, but it worked.
    My xbox with the WD 160gig HD, didn't even hiccup. My xbox booted up fine, and i was able to play my divx files as if it was normal.
    ThoughtS?
    2k3 Max SE 6spd
    Temp setup:
    My 2003 Maxima
    May 2003
    lucky
    Maximum Bitrate none's Avatar
    Sep 2003
    Quote Originally Posted by curtkay
    lucky
    No not at all. My WD has been fine in 0 degree F weather, never a problem at all. Most cold harddrive problems are with Maxtors.
    Jun 2003
    Chicago
    Quote Originally Posted by none
    My 120 gb IBM drive will boot up at 0 degrees or higher, however at temps below 0 it generates a disk error and I have to wait about 2 minutes, reset the computer, and it boots up fine.
    May 2003
    Last week when we had about -15C to -20C All i hd no porblem with the harddisk (an 12G IBM 2,5" from a laptop). But the soundcard on the M10000 board went crazy!!... I didnt hear the music for the first 15min just a lot of distortion.
    But after 15min all work as it should again.
    I havent had any problem at all with my lilliput in cold wether.
    Except the touchscreen that never have worked, not even when i got the screen.
    //Peter
    Quote Originally Posted by MiniRX7
    Mar 2003
    Cool i was just about to post something, along the lines of "HD+Cold weather=?"
