Results 1 to 10 of 10
Thread: problems flashing Epia-M1000 bios
    Mar 2002
    Hey,
    I have an Epia-M1000, with the original bios, I wanted to update to the most recent one listed on Via's site. Since the carcomp does not have a floppy drive, convenience sort of forces me to use Via's flashport utility. However, after I've backuped my current bios rev, and chosen the new one to flash, it tells me that the files is too large, and won't fit. Then it cancels.
    Any suggestions? I've tried a few different bios versions listed on Via's site in the M1000 section.
    birrman54
    Maximum Bitrate carabuser's Avatar
    Aug 2003
    CA
    the only way I could flash the bios was with the floppy drive. No matter what I did using flashport it wouldn't flash it. So my best advice would be try to get a floppy drive, go to the car and do it like that.
    Current Status: For Sale
    Specs
    - 1.5Ghz Toshiba Laptop (available - no screen)
    - Indash Motorized 7" VGA TS
    - DeLorme GPS (sold)
    - Power Inverter (sold)
    - Pioneer HU (sold)
    Aug 1999
    Upper Marlboro, MD 20772
    Damn bastards...why in devils name are their stuff still using DOS or floppy for that matter.
    May 2002
    because flashing from windows is a bad idea (imagine the animal giving a blue screen while flashing the bios ?)
    I don't need no stinkin' startup-shutdown controller... That's what journalized filesystems are for...
    NavSys, the ultimate navigation app
    http://www.navsys.org/
    Mar 2002
    thanks for the replies, I guess I'll pull the comp out and find a floppy I can use.
    birrman54
    Jun 2003
    Chicago
    Quote Originally Posted by Birrman54
    birrman54
    I've experienced the same problem with VIA's flash port utility. Can someone email me the floppy disk files needed to flash the bios via floppy disk?
    ebjustin2@comcast.net
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    NC
    Could you not use a USB pen drive or whatever they are called?
    CarComputer Status: New Car & Broken (Motherboard Fried)
    Owen JH | My Linux Blog | The Tech Fellows
    Jun 2003
    Raleigh, NC
    You can also make a CD. I made a CD and booted to it. Here's the the ISO I made. Its zipped at the link below.
    Once it boots, type "awfl823b.exe i0100113.bin".
    http://home.nc.rr.com/smanders/EPIA_M_BIOS.zip
    EvoX CarPC (in progress)
    Acer Aspire One, OpenPort 2.0 cable, 12V car power adapter, ignition timed relay to unused pins on Ethernet port
    Rhapsody, EcoScan, EcuFlash and still trying to make up my mind
    EvoVIII CarPC retired
    It's not really that small...No, seriously. judoGTI's Avatar
    Feb 2004
    Florida
    Not to revive a thread from the dead, but does anyone have an updated iso I can burn to a floppy? I need to boot and flash my VIA nd dont have a floppy ???
    This .zip doesnt want to unzip for me
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
    May 2002
    easy... burn yourself a copy of FreeDos
    http://www.freedos.org/
  1. DC-DC Converter for C134 EPIA M1000 Nehmiah
    By entr0py in forum Power Supplies
    Last Post: 02-24-2004, 09:22 PM
  2. EPIA M1000 TV out black border problem.
    By Rudical in forum General Hardware Discussion
    Last Post: 01-19-2004, 04:34 PM
  3. Beware of look alikes- EPIA M1000
    By gizmomkr in forum General Hardware Discussion
    Last Post: 10-31-2003, 06:32 AM
  4. Need help with Epia sound problems? :(
    By Skraggy_uk in forum General Hardware Discussion
    Last Post: 08-25-2003, 10:27 AM
  5. Epia and Windows Install Problems
    By Banzai in forum General Hardware Discussion
    Last Post: 08-23-2003, 09:14 AM
