ok.. i have the video out working finally, however.. on the main screen, the resolution goes to 1280*768 while the other is set to 800*600. any ideas as to why its doing this?
ok.. im trying to use the m10000's vga signal (xenarc screen) plus the composite going to another xenarc screen. i can't get the composite to kick the screen on. If i use s-video and dump it to a tv it works, however the vga xenarc screen is not full screen and I can't adjust the tv enough to get it perfect on the screen.
i wish they would just run with nvidia drivers. it would make life much easier.
does anyone have any suggestions on what i need to do? ive flashed the bios and installed the latest video drivers.. what ****es me off still is, those video drivers are over a year old.
I've had problems getting both the VGA and the composite signal to work at the same time. If you have any suggestions as to how you accomplished this it would be helpful to me.
As for your 800x600 problem, I would imagine that it is because TV screens are usually no more than 800x600 (unless you're talking HD). Even with my ATI card, if I go larger than 800x600 it scrolls the screen, i.e. you move the mouse past the right of the screen and the screen scrolls to the left.
2006 Chevy Colorado: VIA M10000 EDEN, 1 GB RAM, 80 GB 2.5" Seagate HDD, USB Slim Slot DVD/RW, Holux GPS, MobileVU 10.4" LCD (touch not working yet), VOOMPC Case (blue), 70W DC-DC supply.
i figured it out actually.. the m10000's interface for tv out sucks.
