Results 1 to 10 of 10
Thread: rca sound card
    Constant Bitrate Sway's Avatar
    Dec 2003
    Muncie, Indiana
    rca sound card
    Im think im going to build a carputer and have been doing research. Theres not much on here about sound card, I wanted to know if there is a cheap sound card (less than $30) that has mono rca out (not S/PDIF out)? I thought about using a 1/8" jack-rca converter but I thought that might degrade the sound quality. Whats your opinion on this and what sound card do you use?
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    SB Live USB, it's got RCA Out, and it's USB if you're doing a low profile case. RCA is stereo, so i dunno about mono... I use it, and i'm currently working out a hum issue (using AC power from my house, not sure what to do>)
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    NC
    I used the jack converter and I didn't notice any decrease in quality but I am sure that RCA is probably alot better if you are going to be running alot of wire
    CarComputer Status: New Car & Broken (Motherboard Fried)
    Owen JH | My Linux Blog | The Tech Fellows
    Maximum Bitrate orangewhip's Avatar
    Apr 2001
    Surrey, B.C. Canada
    Quote Originally Posted by owenjh
    I just bought a gold 1/8 inch jack connector and wired my own "adapter" to hook into the RCAs of my amp. I used good quality RCA cables and cut the end off to wire it to the 1/8 inch connector. Sound quality is good, no hum or noise what-so-ever. And I don't think there is a quality difference between 1/8" and a RCA jack. Just different jacks.
    OrangeWhip? OrangeWhip? 3 OrangeWhips!!
    www.whipflash.com
    Finally a new Avatar!
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    they make a 1/8th to rca wire also. No making a wire
    '98 Explorer Sport
    80% done
    Nov 2003
    Las Vegas/Henderson, NV
    I've used a 1/8 to RCA converter to go from my computer to home stereo and never noticed a hum.
    Hercules Has the Game TheatreXP that has RCA out jacks on the back of the external box it has.
    Apr 2001
    Surrey, B.C. Canada
    Yes I have used a 1/8" to RCA before as well, but if you are really wanting to use nice cable, then you could go the route that I described.
    I actually went that way for space concerns. THe 1/8" connector I soldered onto my RCA was an "L" shaped one, so I could save some space in my install area, otherwise I would have used a prebought adapter.
    www.whipflash.com
    Dec 2003
    Muncie, Indiana
    Quote Originally Posted by Almost a Ghost
    to much money
    Dec 2003
    Muncie, Indiana
    Quote Originally Posted by Pudge
    i cant find it online could u give me a link?
    Newbie GMajor2003's Avatar
    Jan 2004
    Swindon, UK
    Im not sure if this is the one you'll need but im planning to get a MP3+ for my laptop as i have been told it sounds much better, it simply goes straight into the usb connection and has 4x rca output (as well as oher digital input/outputs etc)
    http://www.soundblaster.com/products/MP3+/
    You can get them for around £30 .. although im pretty sure everyone on here is US based? so bout $50 ?
  1. Ewww sound card + video card on dual pci mini-itx reiser card = audio interference
    By psyclobe in forum Software & Software Development
    Last Post: 01-23-2008, 02:59 AM
  2. where can I find low profile sound card?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 11-04-2006, 02:05 PM
  3. got sound?
    By masch in forum Newbie
    Last Post: 11-17-2003, 10:01 AM
  4. Need advice on which sound card to use
    By mtmsol in forum General Hardware Discussion
    Last Post: 06-22-2001, 01:39 PM
  5. help on sound card and rca input/output
    By siq in forum General Hardware Discussion
    Last Post: 09-18-1999, 01:44 PM
