Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: 4.1 Stock AMP - Problems/Questions lexus GS
  1. #11
    Jan 2004
    NYC
    Quote Originally Posted by 00CericaRuss
    I showed my roomate this post and we wandered over to club lexus last night...
    his gs came used w/full tom's coilovers, stainless brake lines, and a trd front strut bar, so he got some free mods... lucky him.
    anyways... if you got an electrical service manual for the car, scan up the pages for the audio and I'll look at it for you, and test on his car... it's the easiest way to figure it out.
    As far as amps... there's alot of good amps out there... it really depends on what you want to spend/what kind of power you want.
    I've got a soundstream reference 405s for sale
    WoW thats some good free Mods have any pics of the GS what size rims?
    Im sure i can get that manual from lexus? that would be great if you can let me know whats what, Maybe your friend wants to do the same thing
    Now as far as AMPS is the one your selling gonna work with my car(replace my stock AMP)can i hook up a USB AugilyNX to it or use any kind of 4.1 sound card?
    Im really not into the sound that much, i think it sounds fine w/stock speakers and sub, how many watt AMP is that
    If the numbers are right ill take it off your hands
    Here is a PIC of my car(lots of Mods), If your friend has any questions let me know, there are sooo many Mods you can do to this car, look me up at CL (under same screen name here) See the Thread i started at CL about this
  2. #12
    Jan 2004
    NYC
    Quote Originally Posted by Vineet Singh
    The Audigy works great as 2ch, all the way up to 7.1 channel. I have it setup as 5.1, but could do 6.1 if I had another speaker (or room for one ).
    I suggest you buy 2 amps, a 2ch (bridged for sub), and a 4channel (all your other speakers), or one 5 channel amp (like mine, but I have a 2 channel as well). Crossover points can all be set internally via the SB audigy 2 NX software, and it's really quite good. I had active crossovers on the amps and just used those in the end.
    yea I think ill go with just one 5 channel AMP
    One of the electronic guys over at club lexus said
    "Be careful in that the stock speakers (front) have 2 ohm impedance values. Rears are 4 ohm and the sub is a 2 ohm"
    Can this be done? not even sure what that means
    Line-inputs for your factory amp... going to be iffy. I know there are equivalent wires on the stock infinity HU's/amps for 2g Eclipse/Talons, and 3000gt/Stealths, but have not found them on various other cars.
    Now when u say Line-Inputs this means if i keep my stock AMP, correct?
    Ditch the HU, replace with touchscreen and laptop, do some wiring and configuring, and you will have a nice setup.
    Yea thats what i want to do, but using a Mini - EPIA MB
    If i cant do it this way, i wont bother doing it at all(too good to be true)....i think this is a great idea, better then having the stock NAV option, ALOT cheaper too
    How would i power the touchscreen?
    If you need help, I have a friend that works at the Lexus Technical Center, and can pretty much find any info on any lexus, if he doesn't know it already.
    I did a seperate volume knob, just desoldered the unit off the audigy nx board, and extended it to the LCD trim panel. Seems to work really well, even has a nice overlay volume bar when you change the vol.
    Thats good to know,maybe you can ask him a question for me can i use a factory AMP without the STOCK HU
    see what he says would be the best way on doing this
    That seperate volume knob is a great idea, but you can also control the volume through the touchscreen(windows) , right?
    thanks again guys for all the help
  3. #13
    Constant Bitrate Vineet Singh's Avatar
    Jul 2003
    Naperville IL
    Quote Originally Posted by robiewp
    dude, where's your spare tire?
    Sweeettt!!!
    I don't have one. I've never needed one all these years, 11? , we have 1 or 2 cellphones on us, and AAA (or allstate bs).
    91 Stealth RT/TT
    CarPuter: Inspiron 5150 P4 3.0ghz; Built-in WiFi; Deluo GPS; Radio Shark; OBD1; Nostromo Speedpad
    Audio: Audigy 2 NX; Clarion 500.5 amp; 100.2 center channel amp; Kicker Solo-baric L7 10" Sub
    Display: Lilliput 7" Touchscreen
  4. #14
    Jul 2003
    Naperville IL
    Thumbs up
    Quote Originally Posted by camsgs3
    Yes, I'm not sure if your stock amp as line level inputs. a 5 channel amp like mine, the APX500.1 Clarion is pretty affordable anyway. Remember one thing though, the sub channel, cannot run in fullpass mode, only low pass (meaning, it can only really be used for a sub, no center or surround speakers).
    You can do it, there are lots of helpful, knowledgeable people on this board, the questions you are asking are the right ones, even though they show you are inexperienced with this stuff. Do some searches for ohms, and speaker basics, move on to the groundloop page at http://www.epanorama.net/documents/g...oop/index.html , and find a friend that knows how to configure weird drivers in windows XP . The touchscreen I used, and lots of other people use, is the lilliput XGA touchscreen, sometimes there is an ad about it along the top/right of this boards pages (lilliput now). It comes with a 12v cigarette adapter, just cut the cig part off, and wire it to a switched 12v source from your car somewhere.
    He said the car's AV stuff is very very integrated with the car, setup for AVCLAN even if you don't have GPS/Nav. He hinted that the amp might be controlled by a "bus" of some sort, and turn on digitally, instead of a simple 12v switched turn-on. i'd say ditch it. The factory speaker wiring should all be at that amp location, and those should be fine to tap into with your 5 channel amp.
    Right. I haven't had to use the touchscreen part yet, except one time when the music was louder than the GPS voice prompts.
    91 Stealth RT/TT
  5. #15
    Maximum Bitrate 00CericaRuss's Avatar
    Jul 2002
    San Rafael, CA, USA
    the amp is a soundstream reference 405s
    it's 1/2 ohm stable..
    here's the values at 4ohms 12v (it will give more power at 14v)
    25x4
    100x1
    it has builtin crossovers.
    I had this running my full system in my old car and it sounded great
    4 - 5 1/4 mb quart
    4 - 10" rockford subs @ 1ohm
    rock solid... slightly low on power, but has never failed on me.
    my roomate wants to pretty much get rid of his deck too.
    as far as his rims, they're just the stock 17's
    Car: 2000 Toyota Celica GT-S
    Mods: Yep
    Carputer: VIA M9000 | Opus 150 | 512MB PC2100 | 60GB Notebook HD | Slim/Slot DVD/CDRW | Audigy2NX | Xenarc 700TSV | (2) DSCustoms DS700HRS (in trunk) | SMC USB 802.11b | CoPilot | DLink FM tuner | Cliffnet
  6. #16
    Jan 2004
    NYC
    25x4
    100x1
    see im really not to sure what all the numbers mean
    will this AMP work in my car?
    what im prob. gonna do is build the pc,indash frame for my 7" then get it installed by a installer
    or do you think i should just get the amp installed by an installer so everthing is working w/stock speakers and HU
    Then I can remove the HU and plug my soundcard into the amp........would it be that easy
    does your roomate wanna do a carPC ?
  1. car battery
    By Slurpee in forum General Hardware Discussion
    Last Post: 09-08-2007, 06:30 PM
  2. Need some help with sending audio to stock amp
    By orangewhip in forum General Hardware Discussion
    Last Post: 09-04-2003, 02:21 PM
