Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Bass hits causing my screen to dim...
  1. #11
    Maximum Bitrate deadweasel's Avatar
    Nov 2003
    Detroit MI
    Quote Originally Posted by NS98GSR
    I have an acura integra and yeah I was considering getting a new battery, or possibly even and additional battery. If I run a 2 plug power inverter off the cig lighter socket and then use an AC adapter for the screen will that change anything? I'm also gonna be running the laptop off the inverter. I'm considering directly wiring it to the battery though since I don't know what guage all the wires are from the cig lighter to the battery so I'm not sure if running both of that socket would be wise. Any suggestions?
    P.S. Any particular numbers (wattage etc) I should look for when getting an inverter?
    Battery would be a big help, but I think the cap idea was dead-on in the first place. Those subs (if they are well-powered) will draw more juice in a hard hit than the system can provide all at once all of a sudden like that. A capacitor is the best way to smooth out the drops that all that bass is causing.
    The ALEXIS Project
    Color Coding :
  2. #12
    Low Bitrate killerfishes's Avatar
    Dec 2003
    a cap for dimming lights is nothing more than a Band-Aid. if all your lights dim I would look for a HO or rewound alt. its called a stiffening cap. not a life support cap.
    now working on my Dodge Dak
    toshiba portege == done
    audigy2 NX == done
    7" flush mount == 0%
    pimp rating == 48%
  3. #13
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Upgrade the alternator to produce more juice and a better battery.
    If you are still using the stock alternator and the battery that come with the car, that problem will still be there even after you add a big cap.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. Gamecube screen
    By junior in forum LCD/Display
    Last Post: 11-24-2003, 06:38 AM
  2. lillyput--all hype?----long review
    By liquid_smoke in forum LCD/Display
    Last Post: 11-21-2003, 10:44 AM
  3. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 02:16 AM
  4. Replies: 13
    Last Post: 07-02-2002, 10:54 AM
  5. NEC Versa M/75 Laptop TFT screen w/touch
    By Macgyver777 in forum LCD/Display
    Last Post: 03-24-2002, 02:14 AM
