Results 1 to 10 of 13
Thread: Bass hits causing my screen to dim...
    Nov 2003
    Southern California
    Will running a big capacitor in line between the amp and battery help me?
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    Quote Originally Posted by NS98GSR
    does it cause your interior and/or headlights to dim as well?
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    Yes, it will help
    Nov 2003
    Southern California
    Quote Originally Posted by Nic
    When I turn the volume up very loud both interior and exterior lights do dim, yes. I was thinking of adding a capacitor a while back but wasn't bothered TOO much by the headlight thing. My new screen seems to be very sensitive to current though and so the bass makes it dim and flicker like crazy when it's up high.
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    All/most lcd/inverter cathode lights is pretty sensitive, I'd say change the charge-regulator for your generator to make it produce a bit mor juice... what car you got?
    Jan 2004
    I have the same problem with my car. I have 3 amps and when I want to be a little bit loud my screens dims. I have a power cap 1.5 f and the external lights do not dim. I guess I need to change the IC for the power supply I built....
    Quote Originally Posted by jol
    Maximum Bitrate tom2112's Avatar
    Nov 2003
    Sharon, PA
    Here's an idea: don't turn it up so freaking LOUD!
    OK, I just had to say it to get it outta my system. Yes, I know: "if it's too loud, you're too old." I guess I'm too old.
    So far:
    M10000 Nehemiah, 1Gb RAM, Opus 90w PS, Buffalo Tech WLI2-USB2-G54, 160 Gb HDD, GlobalSat BU-353 GPS, iGuidance, Zippy EL-610, Panasonic CW8123B Slim Slot CDRW/DVD, 10" Lilliput, Sony XA-300, Sony CDX-MP30 Head, OBD-II
    Constant Bitrate weekendowel's Avatar
    Jan 2004
    Stockholm, Sweden
    Make sure your car battery is in good shape.
    Jan 2004
    I was thinking the same thing about the battery. You might want to consider a Gel Cell battery. A friend of mine has one in his mustang. No carputer, but he runs some pretty hard hitting subs without a cap. by using it.
    Nov 2003
    Southern California
    I have an acura integra and yeah I was considering getting a new battery, or possibly even and additional battery. If I run a 2 plug power inverter off the cig lighter socket and then use an AC adapter for the screen will that change anything? I'm also gonna be running the laptop off the inverter. I'm considering directly wiring it to the battery though since I don't know what guage all the wires are from the cig lighter to the battery so I'm not sure if running both of that socket would be wise. Any suggestions?
    P.S. Any particular numbers (wattage etc) I should look for when getting an inverter?
  1. Gamecube screen
    By junior in forum LCD/Display
    Last Post: 11-24-2003, 06:38 AM
  2. lillyput--all hype?----long review
    By liquid_smoke in forum LCD/Display
    Last Post: 11-21-2003, 10:44 AM
  3. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 02:16 AM
  4. Replies: 13
    Last Post: 07-02-2002, 10:54 AM
  5. NEC Versa M/75 Laptop TFT screen w/touch
    By Macgyver777 in forum LCD/Display
    Last Post: 03-24-2002, 02:14 AM
