Results 1 to 5 of 5
Thread: need a big question anwsered, please help
    Jan 2004
    First i want to say that i have searched the forum and havent found a definitive anwser...so here it goes. I am going to be building my car computer and want to run at least 3 monitors. One would be the lilliput via vga and then at least 2 other monitors via svideo or other video out. it is my understanding that the m10000 does not support dual output? does the mII 10000 support dual out? What video card would be capable with the m10000 and requirements i have if the m(II)10000 can't do dual output thanks
    Newbie mportobello's Avatar
    Jan 2004
    Calgary, Canada
    Do you want the same image on all 3 screens, or a different image on each one?
    The latest Matrox card has 3 VGA outs.
    My ASUS V7700 has VGA + TV out. Using a program like TV Tool you can enable both at the same time. Then you can use a RCA video splitter to split the TV out to the 2 monitors.
    I don't *think* any of the Epia motherboards support dual out. However you might be able try something like TV tool and enable botht the VGA out and TV out at the same time.
    Jan 2004
    Quote Originally Posted by mportobello
    i want the same image on all 3 screens. So the Asus is compatible with the m10000? do you have a link to it? how much did you pay for it? and where do you find TV tool, sorry for all the questions, thanks again.
    Constant Bitrate leenas's Avatar
    May 2003
    I think my m10000 does dual output. I can send the same signal to the tv as the monitor if i chose to. I have the nehemiah as opposed to the ezra if that makes any difference.
    Jan 2004
    Calgary, Canada
    If the m10000 can do dual output then you probably don't need the Asus.
    If you you are looking for it, search for "Asus V7700" on google.
    If you are looking for TV Tool, search for "TV Tool" on google.
  1. How big is too big?
    By infx708 in forum LCD/Display
    Last Post: 01-31-2005, 06:58 PM
  2. Question about BIG 8-pin DIN
    By koyoutou in forum Newbie
    Last Post: 10-02-2003, 04:56 AM
  3. how big is too big if you have got the room
    By bryce_thomason in forum LCD/Display
    Last Post: 03-22-2003, 11:40 AM
  4. Mounting my Datalux and VGA cable question
    By gfoulks in forum LCD/Display
    Last Post: 08-26-2002, 12:35 PM
  5. lcd power question
    By jrbless in forum LCD/Display
    Last Post: 04-07-2002, 01:27 PM
