Results 1 to 7 of 7
Thread: Does anyone make a mini-ITX board with onboard Serial-ATA?
    Low Bitrate Choser's Avatar
    Feb 2004
    I'm aware of the less than spectacular speed benefits of SATA, but I'm still very interested in using in my car, for the extended cable reach and airflow benefits.
    All of the VIA EPIA boards don't seem to offer SATA, which is a bummer. I thought by now, it would be available everywhere. My main reason for wanting this is so I can flush mount and custom mold a slot loading dvd drive in my dash, and I need that long cable run.
    If I don't use SATA, it seems like I can use an IDE to firewire bridge on both ends, or something to that effect, but this is just added complexity that I would like to avoid.
    Thank you.
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    does anyone make a SATA slot load DVD?
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    NC
    Isn't SATA only like 150 where as regular is 133? Maybe I am wrong. I know that MSI have a few MATX boads that support this.
    CarComputer Status: New Car & Broken (Motherboard Fried)
    Owen JH | My Linux Blog | The Tech Fellows
    Mar 2003
    SC
    Gigabyte makes a few boards with sata.
    GA-7VM400AM
    MP300E
    Oct 2003
    Quote Originally Posted by Imatation
    GA-7VM400AM
    Those boards are small, but they are not mini-itx's!! As for SATA boards, I have yet to find a mini that has it, and you would need to have at least 1 standard IDE channel on the board anyways for your optical drives unless you planned on using a USB/IEEE1394 external optical drive. I don't think that they make SATA DVD drives yet... I know you can buy IDE to SATA converters such as this onehere but I don't know if it will work w/ optical drives.
    New CarPC on the way again I think. I miss my old one!!!
    Feb 2004
    I just think that, despite SATA not exactly being leaps and bounds above ATA133... its still better, and should be embraced a little faster. Its just so much cleaner.
    Maximum Bitrate churnopol's Avatar
    Apr 2003
    Delaware!!!
    the new nano-itx board has 1 sata connector
    Falcon cr53 w/ via epia m10000. Nokia 3650 blutooth phone.
    Better than winamp. Click here for qcd player.
  1. Opus and Casetronics C-134 Mini ITX
    By millec in forum General Hardware Discussion
    Last Post: 06-24-2003, 01:31 AM
  2. Xenarc with Mini Itx and Powerstrip
    By Glyn in forum LCD/Display
    Last Post: 09-24-2002, 10:26 AM
  3. mini itx and xp
    By oddcomp in forum General Hardware Discussion
    Last Post: 09-16-2002, 04:20 PM
  4. Mini ITX With 370 Socket
    By marauderz in forum General Hardware Discussion
    Last Post: 07-10-2002, 12:04 AM
  5. Replies: 2
    Last Post: 10-07-2001, 12:43 PM
