Results 11 to 20 of 27
Thread: Is all coax/optical spdif output created equal?
  1. #11
    Jun 2002
    If you could explain this a little more that would be great because some of us might need the education (ok, just me then). I was under the impression that it is not affected by the chassis ground because the signal is 1's and 0's. So you're saying a dvi cable for example can also introduce noise? Thanks.
    Tom
    1993 Probe GT
    Rio Car w/20gb
  2. #12
    Oct 2003
    Watch out, they are different. Some cards do resample before they send data out the spdif ports. Creative cards, nvidia soundstorm does, some others too. The ones that don't sound a lot better.
    Precisely. M-audio cards do not resample. The M-Audio revolution is an excellent buy. You can use Kernel streaming in a Creative card using Foobar2000 so that you can compare the sound quality differences.
    Having said that if you are passing-thru Dolby Digital or DTS streams to a receiver then there is no resample by any audio card.
    Cheers,
  3. #13
    Low Bitrate Choser's Avatar
    Feb 2004
    Does the EPIA-M10000 resample? I really would love to avoid pci cards.
  4. #14
    Low Bitrate killerfishes's Avatar
    Dec 2003
    no. i will bet money on it i have the same AC97 audio chip in my msi im on right now and if spdif is set to 48khz it will not resample. DO NOT CHANGE TO 44Khz.
    as for ground loop. it will only be a problem if you had one to start with. look on the page i posted, it talks about this.
    now working on my Dodge Dak
    toshiba portege == done
    audigy2 NX == done
    7" flush mount == 0%
    pimp rating == 48%
  5. #15
    May 2003
    UK
    I have my home PC connected to a Sony DB940 digital amp with B&W 602S3 speakers, and I can tell no difference between my M1000 digital out and my Sb Live! digital out
    James
  6. #16
    Dec 2002
    Wales
    From what I have just been reading, if a sound card outputs to 48KHz then it does resample, since MP3s and CDs and such are only 44.1KHz.
    So basically, what you want with a non-resampled output is 44.1KHz, if I understand things correctly.
  7. #17
    Constant Bitrate henkbliek's Avatar
    Dec 2002
    Netherlands
    Quote Originally Posted by tbdombrosky
    Yes, the signal is just 1's and 0's, in the real world these signals are represented by voltage levels. Now imagine some pulse being induced on the signal. With an ordinary analog signal you won't hear this (if it's short enough, let's say a couple of microseconds). In the digital line, this pulse will result in a changed bitvalue, so 1 can become 0 and vv. just because the '1' is only 1/4V in reallife (SPDIF) If this happens to be one of the most significant bits in the audioword, this will result in an audible tick.
    And yes, also a DVI cable can be influenced by noise and interference, however I believe DVI uses differential signals, this way the interference will be cancelled out by the receiver (if the absolute level is not too severe). This is also an option for digital audio; you would than use AES/EBU wiring, this uses balanced (110ohms) cable, XLR connections and transformers on both sides of the link.
    And about the [electrical] quality of the SPDIF output; I believe that an SPDIF output should have an output transformer, the M has not.
    Apart from that the output signal is a rather decent ~410mVpp squarewave signal, which drops to ~170mV when loaded. I think that's ok.
    Other guys know much more about resampling, oversampling and things like that so I won't go into that. But keep in mind that no resampling also means no volume control... Doesn't sound very convenient to me...
    white bream
    working on a trilogy: CARGO - UNIGO - MERGO
    CARGO = the Car Computer
    Intel Celeron M, [P]SDC, uBlox GPS, GPRS, WLAN, Silabs FM, RDS, TMC,
    Dual-audio, Onecable TFT, Microsize: 45 x 108 x 168mm (1.8 x 4.3 x 6.6")
  8. #18
    Feb 2004
    170mV? As in .17 volt? Dang.
    Is that good enough for a run to the back of the car?
    As to no volume control... I thought you did have volume control, its just that you had to use the individual slider for wave output.
  9. #19
    Dec 2002
    Netherlands
    Quote Originally Posted by Choser
    You can run such signal over a couple of meters without trouble. A normal audio signal (to amps in the truck for instance) has the acoustic detail in the uV range.
    Does it matter where the original digital audiostream gets recalculated? I don't think so, distortion caused by volume or channel gain scaling will be much worse than the distortion introduced by some resampling stuff.
    Something else you should keep in mind; If you control the volume in the digital domain, then you will loose output resolution.
    When you play with volume at 100%, then you'll use (and hear) the full 16-bit range of the signal (until you're deaf of course ).
    Now, if you turn the level to more acceptable level, you'll loose resolution, 1 bit for every 3dB down. Let's say you play at 24dB below max volume, that is 8 times 3dB down or 1 bit unused. This leaves you with 8-bit of usable resolution... Do you recall how your 80's Atari sounded?
    [Maybe I missed some dB's here and there, but this is the idea. True Hifi geeks can give you all the nasty details for sure. Hint: www.diyaudio.com ]
    white bream
  10. #20
    Feb 2004
    Damn I gotta go to diyaudio.com. You guys sound pretty damn intelligent.
    You have me concerned with adjusting my volume through the PC, which I had planned on doing. My digital output will go to a surround sound processor, which will have its controls including its own volume control, in my glove box (to save space on my dash for the lcd).
    Now I wonder if I should mount my surround sound processors volume control on the dash and use that as the main variable.
