My friend had a Stang he had some subs right next to his box, with no shielding - his subs totally screwed up his hd.
It should be easy to sheild though, and I know his were like right on top of each other.
Ok, i have a question that doesn't seem has been addressed yet. I am putting an Mp3 system and subs in my car. In the trunk i am planning on putting the power inverter, amp, 2 250 watt subs, and a surge protector. Is it safe to put the computer backthere with them? i would think that the subs would screw up the harddrive, but no body that i have looked at has mentioned this.
1988 Chevrolet Spectrum
Pentium 233 / 32 MB RAM
13.1 GB HDD
Windows 98, stripped down, tweaked with Winboost 2000 Gold & TweakUI
350 Watt Power Inverter
Evation.Com's IRMAN
40 x 4 Character Backlit LCD
350 Watt Amplifier
2 12" 250 Watt Subwoofers
4 4" Pioneer Midrange Speakers
ok, so what should i use to shield it if i do put it in the trunk with the subs?
13.1 GB HDD
Evation.Com's IRMAN
350 Watt Amplifier
I have 2 12w6's in mine and everything is fine. I have an external HD and that is in it's own case w/ fan and then the HD in the computer case itself.
Everything is running without any problems.
you could take away a lot of the magnetic waves.
Suppose you have a square sub-box, there's one side where the woofer is mounted. now take the opposite site of that box and mount a big metal plate on the inside of the box.
That should take away a lot of the magnetic waves
_____________
\ sub ||
|___________||
|=metal plate![]()
Hope this helps you out.
Greets
Raas - The Netherlands
ME: VIA epia m10000, lilliput 7', opus 150w, 80gb<br>
GF: IBM Thinkpad 380, ext. 3.5 80gb, 40x4, PB-IR
Hmm
ascii did mess up
nevermind the garbage, but i think you get the point
Greetz
You said 250 Watt subs. Are those Pyramid 350 watt subs or Audiobahn 250 watt subs....it makes a huge difference. All subs are not created equal and different manufacturers either overrate or underrate thier equipment. If they're pyramid then they have tiny magnets and would probably blow if you actually tried putting a real 250 watts to them. If They're JL or Audiobahn etc then they have huge magnets and are probably underrated.
The point: The better the sub, the bigger the magnet, bigger magnets would be more likely to cause a problem.
Catlas
P.S. I've never had my computer next to my 2 Audiobahns so I can't personally relate as to whether it would actually cause a problem.
As long as the hard driv isn't right on the sub magnet which it wont since it will be in an enclosure anyway. Anything more than a foot or so away shouldnt be a problem at all. That should be achivable in most car boots.
Project - GAME OVER :(
You can use anny ferris (I.E. Magnetic) metal to shield them.
Magnetism isn't your major problem, It's the pure vibration of the subs that causes failure of the drive.... I have a hard disk sitting ON a sub for a test once, and it was there for about 12months. It still works fine, but the sub was never operating. Besides the HDD has a huge aliminium chassis anyway, so it's pretty shielded. It's more the physical side that they die from..... Well that's what I've seen anyway. Just mount it in a way so the subs can't shake the crap out of the drive![]()
BjBlaster! Car MP3 & Carputer!
bjblaster.com
"The solution to one problem is only the beginning of another"
