Results 1 to 3 of 3
Thread: opinions on using
    Constant Bitrate JaxPt's Avatar
    Jan 2004
    opinions on using
    I have an older ATX mobo laying around from a gateway pc. I think its samsung, Mp4m-23a, anyway its pretty standard onboard audio, trident video, Lan, 2 usb's. Its running a socket 7, k6-2/500 cpu, 2 dimm slots. I also have a 40 gig western digital with win xp pro and a new 52x cd-rom that I can use. Should work fine if i drop in about 512 megs of pc 133 ram and trim down XP right?
    I want to get a lilliput screen, but i've seen alot of complaints about them so I'm starting to consider getting the xenarc instead.
    For power I'm planning on using an inverter wiring that to dc toggle switch located before the inverter, this way i should be able to control start up/shut down after the car is running by just hitting the toggle switch. I have 4 gauge stinger cable running from the battery to a distribution bock so I can tap power right from my distribution block to an inverter/switch. I had my stereo wired this way in my previous car and it worked fine, so long as you didnt forget to shut down when you got out of the car.
    The seats in the PT are set up pretty high so i have a nice little drawer under the passenger seat that would be perfect to mount all of this with a little mod and the addition of a cooling fan.
    So what ya think, see any snags in the system so far?
    Thanks for the advice
    2003 PT Cruiser
    Sony, DEI, Kicker, Polk Audio, Stinger sound system custom cold air intake, diamond plate floors, progress springs 2" drop
    Freakville Pc's
    The PT Crew
    my cardomain page
    my webshots page
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    my system is similiar to yours and it works just fine. I don't use anythoing on board though and i have a 9 inch widescreen screen.
    The onboard sound might really suck since you have some good sound equipment in your ride so you might wanna look into at least a sb live card.
    '98 Explorer Sport
    80% done
    Jan 2004
    yeh i was thinking of using a sb live or audigy since i can utilize the 5.1 surround sound
    2003 PT Cruiser
    Freakville Pc's
    The PT Crew
    my cardomain page
    my webshots page
  1. need opinions on a mini-itx case
    By a17_track_350z in forum Newbie
    Last Post: 01-27-2004, 01:15 PM
  2. considering laptop, need opinions
    By lstrunk in forum Off Topic
    Last Post: 05-19-2003, 01:04 PM
  3. Any opinions on this eBay item?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 12-13-2002, 08:46 AM
  4. My Project - finished inc Pics - opinions please
    By Phrozenpenguin in forum General MP3Car Discussion
    Last Post: 05-11-2002, 03:47 PM
  5. 2nd opinion(s) wanted
    By sablewagon in forum LCD/Display
    Last Post: 07-16-2001, 07:46 PM
