too much power for the fuse
go buy some decent gyage cable and run a wire from the battery to another cig lighter and put a 16amp fuse on it
if it blows a 16 amp fuse theres something really really wrong
cheers
pcman
every time i hooke up the comp in the car i blow the fuze in the cig adaptor. it worked when i took it for a test run... the only things i have done since then are build a case and add a screen. any ideas? please help!
etrik
"if everything is under control, you're not going fast enough!"
cheers
pcman
donate to my team in the ****box rally all proceeds go to the cancer council http://www.everydayhero.com.au/dodgy_mechanics
My good buddy matt did the same on his Corolla but not only did he blow the fuse, somehow with a 165 watt inverter he managed to blow the entire dash. The fusebox melted i dunno how the hell he managed this. His stereo, clock , and various other dash componoents were out. Not good. he had to replace the entire fusebox. I guess it was that little fuse that didnt decide to blow.
as a precaution, i recommend you stop cease and decist using your inverter on your cigarette lighter and do what pcman said.
Fuses are not precise components. Tolerance may be 800% either way. A 20A fuse may handle 35A for a few minutes before it blows.
It's probably a good idea to run wires directly from the battery. Cig lighters are not really designed for this sort of thing.
Yeah...fuses have severe tolerance issues. I had a 60 Amp fuse on my direct battery tap for my amps and I dead shorted it. It had time to melt the insulation off twleve gauge wire and almost start a fire in my trunk before it blew.
Catlas
If you do decide to run a wire from the battery, make SURE you fuse it somewhere near the battery
If there happened to be a short on the wire running from the battery, it could cause a fire if it wasn't fused near the battery.
MK
Make sure you fuse both the positive AND negative leads to the battery, and fuse within first couple of feet away from the battery. The closer you fuse to the battery the better though you don't have to fuse within millimeters of the posts.
P4 2.4GHz, Intel mobo w/onboard sound & video, 128MB memory, 100GB Seagate Momentus laptop drive, Xenarc 700TSV 7" touchscreen, IRman using Girder, 150W Opus dc/dc psu, Alpine CDA-9835 h/u, MBQuart speakers, Infinity 15" sub, MTX amps.
