is bondo safe to touch? instead of sitting there and sanding and dremeling for hours, can you shape it and smoothen it first using your finger before it dries?
My LCD's actually mounted into the dash (as aposed to the dash cover), so I'm afraid it won't be so easy for me to remodel the dash cover. Yall have any thoughts for extending a faceplate?
car computer rev 5: 8" lilliput and usual suspects
nope, b/c there is no time to do so - it dries very fast ;dOriginally Posted by Crav4Speed
Danny.
"If today was perfect, there would be no need for tomorrow."
My Car Project® ‹== !10.4" Allbrite, touchscreen, epia, 150opus, gps, wireless, sony remote [old] 128x64 Crystalfontz +double din [new]
If you use gloves then its a pain to mold it and make it smooth, everything comes out with rough edges. If you work fast enough and use your bare hands you can usually get it pretty smooth but sanding is ALWAYS going to be needed. Its a very light substance so sanding doesnt take forever.Originally Posted by Sh0cker
is bondo just bodyfiller then? can u link me to a info page, i think its similar to somethin i use at work. thanks,
tom.
Dont know of any links, but if you have ever worked with wood filler its similar in texture and all that. Just dries a lot faster.Originally Posted by mutilator
ok thats what i work withi might have a go at some point
never heard of bondo tho, presumably if i use wood filler with quite a bit of hardner it would be ok. i tend to use fibreglass hardner cus they never give enough hardner with a tin :P
damn.. good job! makes me wanna redo my dash!
Car: 2000 Toyota Celica GT-S
Mods: Yep
Carputer: VIA M9000 | Opus 150 | 512MB PC2100 | 60GB Notebook HD | Slim/Slot DVD/CDRW | Audigy2NX | Xenarc 700TSV | (2) DSCustoms DS700HRS (in trunk) | SMC USB 802.11b | CoPilot | DLink FM tuner | Cliffnet
Thanks, I will show more pics when it's installed into the Jetta.
Bondo is used it auto repairs. It hardens in 2 mintues. Faster than 5 min epoxy.
If you use your fingers to smooth it, it will work well, but only for the first 1 min after mixing. Also you will have to pick the bondo off your finger.
I did ignore the cancer label on it though.
SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
GPSing - Digital Speedo
Relocating headunit and extending faceplate
Button app to Alt-Tab between two programs
You can also use liquid plastic. I beleive all three are the samething, bonda, epoxy and liquid plastic.
