Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 53
Thread: Xenarc + Bondo + Paint + One night =
  1. #31
    Jan 2003
    Ruston, LA
    nice job
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  2. #32
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Thnxs again. Where can I find Vinyl wrap?
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  3. #33
    Newbie mportobello's Avatar
    Jan 2004
    Calgary, Canada
    Awesome job. Thanks for the pictures.
    1997 Toyota Celica
  4. #34
    Dec 2002
    Illinois
    use a small plastic or metal putty knife you only really need the bondo to fill in the gaps and holes and if you want it to dry faster or slower adjust how much hardner you put in it
  5. #35
    Jun 2003
    Memphis - TN
    Very nice work!
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
  6. #36
    Maximum Bitrate brrman's Avatar
    Aug 2003
    Indianapolis, IN USA
    I would suggest anyone using Bondo to use the blue can with fiberglass in it, not the plain red can Bondo. The basic red can stuff will eventually show hairline cracks after repeated heating and cooling. I have seen it first hand. So if you live in a hot climate (Arizona, etc) use the Blue Can with fiberglass. Its easy to work with, just a little stiffer...
    Looksl ike this when applied.
    For the Audi guys - step by step (bandwidth warning!!!)
    Nice work on the screen, btw. Looks great.
    Car: 2000 Audi A4 Avant 1.8t
    Carputer 2.0: removed. Back to stock.
  7. #37
    Jun 2002
    Indiana
    Very nice job! I cant wait till the snow melts, i have so many ideas.
  8. #38
    Newbie BigRedBee's Avatar
    Jan 2004
    PDX
    Is the combination of epoxy and bondo strong enough to hold the touch screen in place? Or did you use some other mechanical fasteners to hold it in the dash??
    I've got a spare radio trim plate that I don't mind hacking -- does anyone know of a source or spare Lilliput front panels in case I a) change my mind or b) screw it up?
    VIA EPIA M10000 | 7" Lilliput Touch VGA | PW70 | 256 Meg RAM | 20 Gig 2.5" drive
    Dual Battery with Optima Yellowtop | Hellroaring Battery Isolater
    ICOM 2720A| Delorme Earthmate GPS | Tiny Track APRS
    Survives Crank
  9. #39
    Aug 2003
    its strong enough definitely. The epoxy is only used to tack the pieces accurately together so you can get the bondo on it without it all moving.
  10. #40
    Low Bitrate TheSpecialist's Avatar
    Jan 2004
    NJ
    Great Job. Looks nice.
    I noticed you didn't do sothing I didn't do the first time I did mine and it later cracked. On your next project drill holes in as many places you can next time. By drilling holes (1/16-1/4 inch is good) the Bondo penetrates to the other side of the plastic. It almost always expands or falls once it's on the other side and kinda works like a rivit. This way you're not just bonding to the surface of the plastic your really bonding to the plastic. In the event the plastic flexes it will pull the Bondo with it instead of try to peel away from it.
    Just a little tip.
    Also I used a Paint called "Exterior Trim" from PeP Boys and it came out since and smoth like the factory GM plastic (an FYI for other GM owners).
    MB 5000*PW70&ITPS*802.11b & Window Mounted Antena*386MB Ram*Shock Mounted 50 GB Laptop HD*Custome Istalled Liliput 7"Touch*GPS*4 Recorded Cameras FT, R, INT, PTZ*Voice & Cell Recorder
  1. paint XENARC 7 inch
    By BOND007BE in forum LCD/Display
    Last Post: 12-29-2003, 09:38 AM
  2. DigitalWWW TM-710VG vs. Xenarc 700YYV
    By sq_geek in forum LCD/Display
    Last Post: 08-12-2003, 10:14 PM
  3. FS: Xenarc 700TSV touch UXGA capable
    By cproaudio in forum Classified Archive
    Last Post: 01-20-2003, 07:38 AM
  4. Xenarc Meta FAQ
    By Skippman in forum LCD/Display
    Last Post: 08-23-2002, 04:11 PM
  5. Xenarc 7" Touchscreen VGA Group Buy.
    Last Post: 07-27-2002, 11:52 AM
