Laying out the bezal over this dash trim he picked out to fill in the hole. (No OEM bezal to work with)
Well my friend tried to install a CarPC and ripped his dash apart and then decided to put it on a stand still.
He offered me some cash to help him build his CarPC and so I started his project last week.
Here is the pictures of the screen fabrication which took me one night only. It was the first time I tried. More sanding was needed but I told him to settle for this finish for now until we get the setup running.
Here's the screen taken apart from the bezal:
SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
GPSing - Digital Speedo
Relocating headunit and extending faceplate
Button app to Alt-Tab between two programs
Done tracing:
Sanding the edges:
Help from the dremal:
Test fit:
Epoxied screen in place to hold...
Mixing Bondo:
Laying some layers on:
Nice and thick coat, cover it everywhere:
After lotsa dremeling, shaping, and sanding.
I used 100, 220, then 400 grit:
