same thing i'm planning on doing....
got a few options...you can use a griffen powermate knob, and that will take care of you volume control, however personally i just dont trust windows with something like that...so I will prolly run mine through an external EQ as well mounted somewhere up front.
each speaker takes one channel. so if you got 4 speakers, you need 4 channels. you can get two 2 channel amps, or you can get one 2/3/4 multi channel amp. not being an expert on car audio myself, I cant say whats better.
your also going to need a GOOD sound card. not the built in junk. grab yourself a Soundblaster MP3+ for $40. its USB and has RCA outputs...should do everything you want. i'm not sure if it does front/back stero out tho.....
LinkBack URL
About LinkBacks
