Results 1 to 6 of 6
Thread: mounting a miniITX mobo
    Jan 2004
    Hello,
    Can anyone tell me the locations of the mounting holes on a miniITX mobo? I want to use the mounting pannel from a standard atx case, cut to size, will the raised holes on this suffice.
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    The holes are in the standard ATX places. They will be the 4 in a "square" going from the backplate
    So you can use it in any ITX/ATX case
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Bowel movement jjh221's Avatar
    Dec 2003
    not sure yet.
    try... firt whole then 6 3/16" x 6 3/16" and from the first whole you made parallel to the third whole you just made 5 3/16" should be right on.
    Jan 2004
    cheers guys
    Dec 2003
    not sure yet.
    cheers? you got beer? hehe yup
    phc
    phc is offline
    Variable Bitrate phc's Avatar
    Aug 2003
    SoCal
    Quote Originally Posted by lummox
    Hello,
    See attached pdf for hole locations. Dimensions in mm unless otherwise noted as inches.
    www.mechatroniks.com/wrx - Car PC Project/Dash Kits
  1. Must I get a "fanless" mobo?
    By -al- in forum General Hardware Discussion
    Last Post: 09-03-2003, 08:23 PM
  2. FS: Celeron 500, Mobo, Ram $40
    By surfer6262 in forum Classified Archive
    Last Post: 03-27-2003, 08:34 AM
  3. Properly grounding mobo
    By BMp3W in forum General Hardware Discussion
    Last Post: 11-17-2002, 10:50 AM
  4. Methods of mounting?
    By MP3DUB in forum General Hardware Discussion
    Last Post: 10-01-2002, 06:40 PM
  5. hardware woes - just venting!
    By magnetik in forum Off Topic
    Last Post: 05-21-2002, 04:31 AM
