Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: Head Unit -vs Head Unitless Install. Pro's and Con's.
  1. #11
    Maximum Bitrate eCarô's Avatar
    May 2003
    SE Michigan
    I an going to be HU-less also.
    I still want radio preset buttons on my dash. I think I'll be able to work that out by hacking into a keyboard/keypad so that each one of the buttons on my dash presses a keyboard key. Then I can use Girder to assign those keys a task, like change radio station. If you use number pad keys, then they each could have 2 functions by turning numlock on/off.
  2. #12
    Dec 2003
    What type of sound card are you all using to get from the carputer to the amp. Do you all just use a headphone cable with two RCAs on the end to go into the amp and how do you control the treble, bass, and sub woofer. Most high end head units have sub woofer rca outs. I will be using two amps one for my sub and one for my mids.
  3. #13
    Constant Bitrate Magnezium's Avatar
    Oct 2003
    Los Angeles, CA
    I have a Pioneer 8500, and I have to say that it's the best way to go for me. I've gone head unitless and I've gone with the head unit... Let me be honest, it's easier and takes up less space to go with out a head unit. However, I was using crappy head units before. This head unit is much better. It has a very good EQ and volume control. Not to mention I use AM for news and traffic. Also, I don't have to completely go through the PC to listen to CDs when sometimes it's just easier to go through the head unit. Most importantly, my unit has Super Tuner III so I get MUCH better FM quality than any other FM I've ever heard. I don't even have an antenna.
    One more thing... In my car, the shifter in 3 inches away from my head unit. On the head unit the buttons actually fold out and extend to my fingers on the shifter!!! I NEVER have to move my hand off the shifter. I'd NEVER give that up.
    Mg.
    Just your friendly neighborhood computer specialist.
    2002 Pontiac Trans Am WS.6
    Silver/Black
    Looks like new... Wanna know why they call me "Crash"?
  4. #14
    Low Bitrate Crav4Speed's Avatar
    Nov 2003
    New York City
    headunitless... M10k, Opus 150 watt, laptop dvd, WD 120Gb hdd and lcd is going in the double din space... nothing in the trunk... that alone is worth it to me
  5. #15
    Variable Bitrate kiztope's Avatar
    Nov 2002
    In the car
    So, what does everyone use for a sound card?
  6. #16
    Maximum Bitrate jusatry's Avatar
    Nov 2003
    i am going to be head unitless soon...i plan on using the MP3+ soundcard with a 6 channel passive EQ mounted in the glovebox. I am also gonna use a david navone 2 channel line driver before the EQ to boost the stock amp a bit if needs be. I have a sub/amp setup in the trunk, so i will run my cub output from the EQ to the trunk. About the popping on, i plan on putting a switch in line with the remote turn on for the EQ (thus stopping all sound if its switched off). This way, not only do i have the ability to avoid the popping sound, if windows goes crazy or whatever (which we all know it can), i have a quick way to shut off all sound. Also, if i get a phone call, or, more drastically get pulled over, i can shut sound off instantly, without having to deal with software issues. I know this sounds like a pain, but if it gets too bad i could wire in a timed relay and leave the switch on all the time, just using it as a quick disconnect.....as a matter of fact, i think i will do that. Anyone have any suggstions about a relay delay (i am a bit of an electronic newbie).....
    thanks for posting this thread leslie, made me think it through!
  7. #17
    Variable Bitrate mutilator's Avatar
    Jul 2002
    Staffordshire - united kingdom
    that relay would just be a standard 12v relay i guess, i aint done it yet, but im sure it will work. usin onboard 4chan from the epia till i get my subs in.
  8. #18
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    I'm going headunitless as soon as I get everything installed back in the car. I'm doing some minor tweaking right now. But I have an Audigy 2 ZS going into a Clarion EQS-560 which has a sub, fade, and Vol. control on it as well as a 5 band EQ. It will put out 7V. on the preouts. The highs and lows will go to a Kicker KX600.4 and the sub output will go to a Kicker KX400.1. I'm hoping it will sound great when I'm done.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
  9. #19
    Banned NightHunter's Avatar
    Dec 2003
    Milwaukee, WI
    I too will HU less when some one imbeds a good XM capability in to a stable carpc front end.
  10. #20
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    I'm adding a 12 volt toggle to turn of amps if I have too. Just tapping into the accesory turn on lead.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  1. Pros and Cons to Designing a Front End using Flash?
    By Superfly in forum Software & Software Development
    Last Post: 12-01-2002, 09:40 PM
