Results 21 to 30 of 32
Thread: Head Unit -vs Head Unitless Install. Pro's and Con's.
  1. #21
    Maximum Bitrate MikeHunt79's Avatar
    Aug 2001
    Cambridge & Bristol, UK
    Headunitless here... I have a switch for my amp, which i flick once the comp is booted.
  2. #22
    Maximum Bitrate albysure's Avatar
    Dec 2000
    pittsfield, ma.
    what i did for the popping is i bought a delay turn-on circuit from http://www.davidnavone.com/detail.asp?PRODUCT_ID=N-66A it is adjustable from 0 to 30 seconds and works great
    also my main volume knob is on the surround processor mounted indash. you should be able to get a pre amp level volume control somewhere
  3. #23
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Sounds like I found a mute button and a nice way to turn on the amps 30 seconds later. I hope thats enough, I wonder if you can wire two in series to get 60 seconds?
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  4. #24
    Dec 2000
    pittsfield, ma.
    well. i suppose you can use the first one to trigger the second one to get your 60 seconds...right?
  5. #25
    Jan 2002
    Long Island, NY
    Quote Originally Posted by albysure
    Yup and you can fiddle with both to get 2-60 seconds.
  6. #26
    Feb 2003
    SE Ohio
    WITH Head Unit
    Well This is what I've got:
    Sound Blaster Live 4.1
    Jensen MP3-CD player w/ IR Remote & AUX
    --This drives 2 Infinity 3.5" 2 ways w/ 1" Tweets
    200 (rms) Watt Radio Shack amp
    --This drives 2 Sansui 6 way speaker boxes
    ----Each Box has: 15" Woofer, 6" mid, 2 6" horns, 2 1.5: Tweets
    I'm current routing the fronts to the AUX on the head unit (which turns on the AMP via the AMP Relay wire). The Rears (which also carry the bass frequencies) are aptly routed to the 200W amp, and the Sansui's.
    It works pretty good. I just make sure to have the head unit off during PC power up.
    When I turn the car off (with the stereo on) I do have a 3 or 4 second delay before I get a pop as the power drains from the amp.
    The reason I went this way is though the carPC is a semi-permanant install I still want to be able to have tunes upon PC removal.
    Oh yeah, you're proably wondering how I control volume, I do that with mouse.
    If you're not paranoid, then you're not paying enough attention. -kmfdmk.com
    http://www.mymp3car.com/MP3Car/PSUpower.asp
    1985 Supra 7M-GTE
    10.4" Planar LCD
    ECS GOAL3+ mobo w/ 512mb + 8GB sdhc
    Edimax EW7318USG Wifi w/ 7 db Ant.
    USB GPS
  7. #27
    Constant Bitrate psyclobe's Avatar
    Oct 2003
    Quote Originally Posted by kiztope
    So, what does everyone use for a sound card?
    Sound blaster extigy
  8. #28
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Audigy 2 ZS
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
  9. #29
    FLAC robiewp's Avatar
    Dec 2003
    Massachusetts, US
    audigy 2 nx
    car computer rev 5: 8" lilliput and usual suspects
  10. #30
    Banned NightHunter's Avatar
    Dec 2003
    Milwaukee, WI
    Also when HU Less plan on not getting great FM reception, you may get OK reception in some areas, but crappy in others. I live ony a few miles from a major radio station and it comes in like crap using the D-Link apperatus. I am now using my head unit and sold the d-link. I tried a few mods on it but the quality just wasnt there. Anyway give me XM and I will give you my HU....
  1. Pros and Cons to Designing a Front End using Flash?
    By Superfly in forum Software & Software Development
    Last Post: 12-01-2002, 10:40 PM
