Page 4 of 4 FirstFirst 1234
Results 31 to 32 of 32
Thread: Head Unit -vs Head Unitless Install. Pro's and Con's.
  1. #31
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    I plan on using my Audigy NX2. - But I noticed you cant plug in mic and line in at same time or you get distortion. - So I bought a iMic USB mic/headphone adapter so I don't have to run a RCA to the rear when I move my soundcard to the trunk where the amps are.
    I have the Dlink and the recpetion is the same as my headunit becasue I tapped into the antenna line and my STi has a built in antenna amplifier cause my antenna is in the rear window. -If I unplug the headunits antenna, the D-Link gets better and if I unplug the D-Link the stereo gets ebtter, so when I get rid of my HU, the D-Link will have better reception. The only thing is the D-Link picks up some ground noise, but not much and even less when the Headunit is detached.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  2. #32
    Variable Bitrate kiztope's Avatar
    Nov 2002
    In the car
    So, is anyone using the Hauppauge Win-tv/Fm to get FM radio??
  1. Pros and Cons to Designing a Front End using Flash?
    By Superfly in forum Software & Software Development
    Last Post: 12-01-2002, 10:40 PM
