Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Does cold affect boot time?
    Maximum Bitrate XxAndyxX's Avatar
    Dec 2003
    Edmond, Oklahoma
    I just got my Carputer installed a couple days ago and I'm finding alot of stuff out (good and bad). This morning was the first realy cold morning since I've had my CarPC and my car sits outside... So start up my car and the computer sits at the BIOS screen forever. Then when it booted up MediaEngine actually froze and everything just seemed to be going slower than usual. My computer is a 2.2Ghz P4 with 512 DDR so this should definitely not be happening but is it an affect to the cold or do I have some other problem?
    -It was about 15F
    Oct 2003
    Toronto, Canada
    no, in fact the colder the better. Unless you got condensation in there, than you're screwed. heh.
    VIA Epia II
    256MB 266DDR Ram
    90GB Wester Digital
    Bluetooth/Deluo GPS
    Lilliput 7" Touchscreen
    Mazda 6 Carputter > Click Me!
    Newbie saito's Avatar
    Dec 2003
    NE
    First, the answer above is BS, FYI.
    As has been discussed, ad nauseum, hard drives have an operating temperature range. Too cold, they won't boot. Too hot, they won't boot. Also, as has been discussed, condensation is a non-issue.
    I have found when the temperature range is between 10° and 20° F, the computer will boot sometimes, but it may hang or "freeze" shortly thereafter. Other times it hangs in the POST because the drives aren't spinning and aren't recognized by the BIOS.
    Below 10°F the ITPS Power Sequencer will not let power flow to the computer.
    Aku, Soku, Zan.
    Epia M10000 Nehemiah
    Lilliput
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    condensation a non-issue? I thought it was a known fact that condensation and computers don't mix.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Dec 2003
    NE
    See this thread re: condensation
    Carputer Condensation
    Aku, Soku, Zan.
    Lilliput
    Maximum Bitrate deadweasel's Avatar
    Nov 2003
    Detroit MI
    Quote Originally Posted by saito
    Saito's got it down alright, although I would argue that some of the older drives (without fluid bearings) are able to work outside their stated range by a small margin. Don't depend on that to be the case with yours though. It's better to play it safe and make sure the system doesn't get too hot or cold, as it can (and often does) affect the system's ability to boot properly. There are many threads regarding this issue here in the forums. Well, okay, one big one that I know of: Cold Weather Hard Drive
    BTW, Saito: would your nick/avatar be from Rouroni Kenshin by any chance?
    The ALEXIS Project
    MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
    Color Coding :
    DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
    Maximum Bitrate none's Avatar
    Sep 2003
    I've never had this problem, with temperatures even colder than that. I have the regulator on my ITPS bypassed, but I doubt that would make a difference.
    Never a problem with my Western Digital harddrive either.
    Nov 2003
    Detroit MI
    Quote Originally Posted by none
    *whispers to member sitting nearby*
    psst.. he used the "n" word man! He's screwed now!
    The ALEXIS Project
    Color Coding :
    Dec 2003
    NE
    DW -
    Hajime Saito, Shinsengumi member. Coolest character in RK. As the sig says: Aku, Soku, Zan.
    Aku, Soku, Zan.
    Lilliput
    Sep 2003
    lol, not superstitious either.
  1. Oh where have all the Shutdown Controllers gone (and boot time)?
    By SuperAJ in forum General Hardware Discussion
    Last Post: 05-21-2005, 09:57 PM
  2. Reducing my boot time bit by bit.
    By themurph1018 in forum General Hardware Discussion
    Last Post: 11-16-2004, 06:39 AM
  3. whats the average boot time for a g4 or g5 apple?
    By churnopol in forum General Hardware Discussion
    Last Post: 12-19-2003, 06:57 AM
  4. Using DOS and 98 at once, can I toggle at boot time with a keypress?
    By bombboyer in forum Software & Software Development
    Last Post: 04-07-2003, 11:13 PM
  5. Fast boot time 350mb ide flash disks!
    By Mp3 V in forum Classified Archive
    Last Post: 02-15-2002, 06:58 PM
