Results 1 to 4 of 4
Thread: Mini-ITX Beeping when I turn it on
    Oct 2003
    I got a new power supply for the mini, but now, when I turn it on, it just goes beeeeep....beeeep....beeep...and keeps doing that, nothing else. What's going on here? I couldn't find any beep codes in the manual.
    Dan
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    check all the connections. Make sure the RAM is seated propperly. and try a different PSU just in case.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    NC
    Normally it means memory, or video since the video is on board its probably the ram. if you have 2 sticks in there try replacing them, if you have 1 make sure its in the #1 slot, I don't think it matters as much anymore but its worth a try.
    CarComputer Status: New Car & Broken (Motherboard Fried)
    Owen JH | My Linux Blog | The Tech Fellows
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by owenjh
    I agree. Constant long beeps means the BIOS does not see the memory. See this a lot.
  1. no mini itx between 1ghz eden and P4 2.4Ghz?!
    By Henke in forum General Hardware Discussion
    Last Post: 02-04-2004, 05:11 PM
  2. Opus and Casetronics C-134 Mini ITX
    By millec in forum General Hardware Discussion
    Last Post: 06-24-2003, 12:31 AM
  3. mini itx and xp
    By oddcomp in forum General Hardware Discussion
    Last Post: 09-16-2002, 03:20 PM
  4. Mini ITX With 370 Socket
    By marauderz in forum General Hardware Discussion
    Last Post: 07-09-2002, 11:04 PM
  5. VIA EPIA Mini ITX beeping problem
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 06-28-2002, 10:31 PM
