Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Aiwa CDC-MP3: Aux Input
    Jul 2000
    Post Aiwa CDC-MP3: Aux Input
    I am looking for an auxillary input adapter for the Aiwa CDC-MP3 (it has cd changer controls built in). I know it has Aux in on the front, but I'd rather not have a cord running into the front of the radio.
    Anyone have any idea if such an item exists?
    If it doesn't, anyone know how I would begin to hack one together?
    Thanks,
    TP
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post
    If you're brave, you could open the thing up and wire up a 1/8" jack on the back, and solder it to the connections on the front of the player on the inside...
    Jul 2000
    Post
    I think I may try that. However, it won't be that simple because the face is detachable and all of the connections on it (including the front aux in) get routed through a central connection to the main unit. I'll have to figure out where the aux in signal ends up.
    Another option is to come in through the cd changer input. I would prefer this since there would be no modifications to make. Any ideas how to get started on finding what connections do what? Links anyone? (I've searched the board extensively on this and have found very little concrete info.)
    In general: Is there a certain connection that has to be grounded in order for the head unit to think that there is a changer attached? Is there anyway to find out this info?
    I suspect there is not after reading all the posts I could find on this board so I am going to look into hacking into the front aux in.
    Oct 2001
    fayetteville, nc
    Post
    hey, i have the same player. if you look at the terminals with "aiwa" right side up the ground is the back right. the left is the top right and the right is the top second most right.
    I may be able to help you further but don't want to take it apart tonight
    And I think there has to be some something to trigger the cd changer because it skips the "cd changer mode" when flipping through the functions.
    As for the cd changer input...i'm clueless. Maybe if the aux in went to same place you could do a continuity test between the two?
    Feb 2001
    louisville,ky,usa
    Post
    I was thinking that the Aux-In on the front was not part of the Face, since it seems like the face is not quite 1/2 inch thick, but i guess I could be wrong. I thought this had been done by someone on the board already.
    I cheat, I own an empeg.
    Meskimen's Law: There's never time to do it right, but there's always time to do it over.
    http://civic.mp3car.com
    Maximum Bitrate smashr2k's Avatar
    Jun 2000
    Virginia
    Post
    Yeah, i got an aiwa unit, and i posted a picture of the circuit board here, trying to figure out how to solder the connections for aux in. It would be really nice to eliminate that cord in the front if someone can figure out how.. I never did.
    http://www.tjhsst.edu/~dbagley/cdc-x507m-board.jpg
    http://www.tjhsst.edu/~dbagley/cdc-x507m-board-big.jpg
    Car: 1999 Dark Green Mustang GT Coupe
    Audio: Alpine HU, JL 6ch Amp, JL Stealthbox and XR series components.
    Player: Empeg for now; something custom later.
    www.neotechpc.com - Custom built laptops!
    Dec 2001
    Post
    I was able to open my Jensen cd player and tapped the lines fron the CD player part, this works great although I need to have a blank cd playing at the same time.
    Dec 2001
    W. Lafayette, IN (School) Schaumburg, IL(HOME)
    Post
    I'm not sure if this helps but on the Blaupunkt in my car, it had an aux input that wasn't listed anywhere on the specs. There where a whole bunch of pins that weren't being used by anything so I tested them out and found that 2 were left and right inputs. I split the audio out from my comp to RCA left and right and then cut off the plugs and attached the wire directly to the pins using a male to female serial converter that just happend to fit perfectly. Anyway, maybe your reciever has some sort of aux input like that. Good luck
    1990 GSX Eclipse
    5in Sharp LCD
    P.O.S. Computer
    Wireless Trackball Mouse
    Sonique MP3 Player w/ Bigfoot Zoom Software
    Nov 2001
    LI, NY
    Post
    OT to Got Nookie?,
    Just curious, what is Bigfoot Zoom Software?
    97 Dodge Ram 13.8" touchscreen/DVD/GPS/TV/FM
    Some pics & details here
    Jun 2000
    Virginia
    Post
    any luck with the rear aux in on the aiwas? what about emulating a cd changer? anyone know the pinouts?
