Results 1 to 8 of 8
Thread: IDE to USB
    Variable Bitrate Freeman's Avatar
    Aug 2003
    Australia
    Question IDE to USB
    what u guys think... if i hack this case
    http://www.centrecom.com.au/catalog/...a1cca3aaebee9d
    and i just hack the box apart to get the components out... it says its ide so it should connect straight up and its usb 2.0 and its only $27.50 AUS
    It aint no family car.
    SEE MK2 At : -
    http://www.mp3car.com/vbulletin/showthread.php?t=22810
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    What exactly are you looking to do with this? It does say IDE but it's for a laptop drive. Also, I think you can get the same thing for less.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Aug 2003
    Australia
    connect it to a slim line cdrom..cause my pc is in the back and i want the cdrom is in the front
    just thought it would work cause it says IDE.. mind u i have a ide converter on the back of the slim cdrom
    SEE MK2 At : -
    Oct 2003
    you can buy an IDE to USB adapter w/ out having to hack this case. Check it out Here
    There are alot of other ones like this... so why waste a good case. Also you could just use the actual case and hide the drive under your seat.
    New CarPC on the way again I think. I miss my old one!!!
    Aug 2003
    Australia
    a slim drive wont fit in the case which is the problem..
    SEE MK2 At : -
    Aug 2003
    Australia
    also, by the time i pay for p&h and currency conversion it would be about the same
    SEE MK2 At : -
    Maximum Bitrate albysure's Avatar
    Dec 2000
    pittsfield, ma.
    i'm also looking for a usb 2.0 to ide adapter to use on my dvd drive but am concerned about the additional power needed. i found another adapter on ebay that requires only 3 volts. the power pack is rated at 1.5 amps. i found a radio shack 12v adapter that is only rated at 1.2 amps. i'm wondering if i should try this one or try to get an adapter that uses only 12v. anybody?
    Banned NightHunter's Avatar
    Dec 2003
    Milwaukee, WI
    I picked one of these same cases off ebay for $9.99, plus $5.00 s/h.
    link on ebay
  1. IDE to USB?? or USB slim slot load dvd drive
    By mercury in forum General Hardware Discussion
    Last Post: 04-07-2008, 12:50 PM
  2. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
  3. WTD - Usb to Ide Converter
    By petemal2000 in forum Classified Archive
    Last Post: 10-07-2003, 12:07 AM
  4. IDE -> USB?
    By guitar333 in forum General Hardware Discussion
    Last Post: 08-15-2003, 02:57 AM
  5. WTB 3.5 IDE USB Enclosure
    By lzrdkng14 in forum Classified Archive
    Last Post: 06-18-2002, 07:56 PM
