Results 1 to 5 of 5
Thread: Via M10000
    Jan 2004
    Via M10000
    Hello can anyone tell me how tall the processor with heatsink anf fan is? and whether this is more or less than the standard pc2100 ram.
    Is there a minimum clearance from the ram or processor and the top of the case i am making?
    So basically what is the minimum height of a m10000 case?
    thanks
    Maximum Bitrate brrman's Avatar
    Aug 2003
    Indianapolis, IN USA
    Cases are different sizes - some can't hold regular ram and need low profile ram.
    Do you not have the M10000 yet, but are making a case to fit one? I'm not really sure of the dimensions.
    Car: 2000 Audi A4 Avant 1.8t
    Carputer 2.0: removed. Back to stock.
    Maximum Bitrate tom2112's Avatar
    Nov 2003
    Sharon, PA
    Lummox,
    The M10000's processor, heat sink, & fan are 33mm tall. That's 33mm from the bottom of the board to the top of the fan.
    The RAM I have in mine is standard size, and 37mm tall - bottom of the board to the top of the RAM.
    Those measurements don't include the solder leads/joints that stick out from the bottom of the motherboard. So you want to add 5mm for motherboard standoffs. A 1mm plus or minus clearance would probably be a good idea too. So I would say that the minimum inside dimension (height) of a M10000 case would be 43mm with standard RAM or 39mm with low profile RAM.
    Hope that helps,
    Tom
    So far:
    M10000 Nehemiah, 1Gb RAM, Opus 90w PS, Buffalo Tech WLI2-USB2-G54, 160 Gb HDD, GlobalSat BU-353 GPS, iGuidance, Zippy EL-610, Panasonic CW8123B Slim Slot CDRW/DVD, 10" Lilliput, Sony XA-300, Sony CDX-MP30 Head, OBD-II
    Jan 2004
    Tom,
    Thanks for your very detailed reply.
    It does help
    Nov 2003
    Sharon, PA
    No problem. It just so happened I was sitting here next to my M10000 and there was a ruler handy.
    Ooops. I missed something important. I was just looking at my M10000, and I realized that the sound jacks stand higher than the heatsink/fan combo or even regular size RAM. The housing around the sound jacks stands 40mm high, so add 6mm (one for a little give/take and 5 for mobo standoffs) and your minimum interior case dimension is 46mm.
    So far:
  1. Shuttle XPC or Via Epia m10000???
    By RaZor in forum General Hardware Discussion
    Last Post: 06-04-2004, 10:35 PM
  2. Difference in two M10000 MoBo's
    By jinx8402 in forum Newbie
    Last Post: 01-29-2004, 10:27 AM
  3. Will this VIA EPIA M10000 setup work properly??
    By b5b4you2 in forum General Hardware Discussion
    Last Post: 01-20-2004, 09:12 PM
  4. EPIA M10000 System For Sale
    By johnram in forum Classified Archive
    Last Post: 11-18-2003, 09:11 AM
  5. VIA M10000 Dimensions
    By SiGmA_X in forum General Hardware Discussion
    Last Post: 10-14-2003, 07:44 PM
