Results 1 to 5 of 5
Thread: Double Dinn Radio
    Registered User belezeebub's Avatar
    Dec 2003
    Double Dinn Radio
    OK, (being lazy here I admint it) I don't have a double din radio to measure can anyone post HxWxL for a double din radio (I have an idea for a porject but before I start I need to know if it will fit.
    (its a Secret project but if you promisse not to tell I'll give you a hint)
    I want to find a broken one of these
    GUT it out and Build the screen into the drop down part and put a Epia 1000 into the back, DVD will mount into the cd slot, bingo a all in one car-pc that can be moved from car to car with ease.
    No copying my idea
    Low Bitrate Crav4Speed's Avatar
    Nov 2003
    New York City
    standard DIN is 7"x2" so double din would be 7"x4"... the depth changes from car to car but a standard din radio, I believe, is 7"... good luck
    Dec 2003
    Dang one more good idea shot to hell, if a double din is only 4 inches high I can't squeese a 4.2 inch display into the hole.
    and the 5.8 Inch screen is even taller 108mm vs 103mm
    Quote Originally Posted by Crav4Speed
    Apr 2003
    Quote Originally Posted by belezeebub
    A widescreen 7" screen like the Lilliput would fit. I have a double DIN radio and the Lilliput housing is just slightly taller (by about 2mm) than the double DIN slot.
    Nov 2003
    New York City
    umm... a 4.2" screen will fit in a double din space... 4.2" is the diagonal length of the screen... with a 4:3 ratio screen, the height will definitely be no more than 2.5"
  1. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 04:34 AM
  2. xenarc in double din? or digitalWW
    By infinitiqx4 in forum LCD/Display
    Last Post: 12-12-2002, 12:29 AM
  3. Car radio "hack" is EASY!!!!
    By THEMP3KID in forum General Hardware Discussion
    Last Post: 07-19-2002, 10:48 PM
  4. panasonic car radio
    By babas151 in forum General Hardware Discussion
    Last Post: 05-31-2002, 08:19 PM
  5. What do you use for radio?
    By accord in forum General Hardware Discussion
    Last Post: 10-12-2001, 03:10 AM
