Results 1 to 6 of 6
Thread: Via Epia M10000 power button
    Feb 2004
    Hi
    I'm new to this forum - i'm doing a pc build in a landrover 90
    my question is this - can the power button be used to initiate soft shutdowns? i know this is a function that is controllable by windows, but presumably the mother board has to be compatiable.
    if it can be - i'll be looking at a system to shutdown the pc when the ignition is turned off
    Luke
    Oct 2003
    Yes... but that is controlled by windows
    New CarPC on the way again I think. I miss my old one!!!
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    Quote Originally Posted by LandyLuke
    Hi
    One word: Opus
    Welcome to the forums, by the way
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Feb 2004
    Cheers Guys
    whats an opus? if it has any bearing on your replies - i'm planning to fit the m10000 into a travla c134 case, and i'm looking at this power supply
    http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3460619022
    Aug 2003
    Essex, England
    Do a search for Opus.
    With that combo you're looking at (ITPS and PW120/PW120A) you still will not get the best power setup. The Opus is the best. It probably won't fit in the c134 case, but that's cos it's so good.
    You can find out all you need about the Opus by a simple
    Garry
    www.aimee.cc
    Feb 2004
    wiring up an opus with a travla c134 would be near impossible - gettin an ats power loom into the case is not going to happen!!!
    i dont think the opus does anything that the audioforge doesn't especailly as i'll be running it of a seperate battery thus eliminating engine starting spikes - and it will fit into the case with the mobo - a tight fit in the c134!
  1. linking into laptop power button
    By corsamel in forum General Hardware Discussion
    Last Post: 04-23-2010, 05:53 AM
  2. Relocating computer power button
    By King_Xerxes in forum General Hardware Discussion
    Last Post: 02-21-2007, 10:15 PM
  3. m10000 won't power up
    By swzine in forum General Hardware Discussion
    Last Post: 11-23-2003, 03:49 PM
  4. EPIA M10000 System For Sale
    By johnram in forum Classified Archive
    Last Post: 11-18-2003, 10:11 AM
  5. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 03:36 AM
