Results 1 to 6 of 6
Thread: Motherboard POST time
    Dec 2000
    Bellevue, NE USA
    Post Motherboard POST time
    The motherboard that I am currently using takes about 30 seconds to even begin its POST. Are there ways to decrease the POST time? If not, are there any motherboards with minimal POST times?
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Cool
    Ouch, 30 seconds is a long time...
    First, manually enter all the settings for your hard drives, or use the autodetect feature to detect them. Don't leave everything set at auto or the motherboard will redetect all IDE devices at startup. This takes a lot of time.
    Set all your port information manually...that is, change the settings for your serial and parallel ports from AUTO to the proper settings.
    Enable fast boot, and disable the floppy controller as well as boot from floppy. Also, disable memory test above 1MB.
    That's all I can think of at the moment...
    Apr 2001
    Here, There, Everywhere
    Post
    my ASUS motherboard has a great BIOS with wicked POST time (under 1 sec). But I was just lucky to get that mobo at the time..
    Project - GAME OVER :(
    Jan 2001
    Adelaide, SA, Australia
    Post
    My computer (desktop) hangs for a few seconds AFTER post. Where it would usually say Starting Windows 9x... It sits there for about 10 seconds before it starts to load windows. Strange
    http://www.mp3vl.tk Plans and progress on my install - (Updated 28 June 02)
    Australian mp3car Portal
    mp3car related links Check them out / Add some
    mp3car FAQ - RTFF
    [########==]80% Assembling
    -=Current Progress: Working Sproggy supply, building box.=-
    Apr 2001
    Madison, WI
    Post
    OK here are few things I learned how to make short boot-time.
    First hardware,
    1) try to eliminate extra hardware you don't need.
    2) for the memory chips, put the memory chip in first socket and if you have more than one put bigger memory chip first . (believe or not , for some motherboard ,it will make the computer boost faster)
    3) use good hardware, I know this is basic but it's important!, good motherboard, decent hard drive (at least 7200 speed) and use ATA100 cable if your hard drive spports it.
    Second the BIOS
    1) update the bios latest version.
    2) in your bios setting, like 'Aaron' said
    a) use maual setting for the IDE drives, don't use auto setting.
    b) use fast boot option (if it has it)
    c) diable booting from floppy drive. make the the hard drive is the first one in booting sequence.
    e) disable the memory test.
    Third in Windows;
    1) Install ONLY porgrams that you use , specially don't install programs that need to be run in background all the time if you can. Such as virus program , if this is for Car PC, virus program is unnecessary I think.
    2) Try not to have any short-cuts in desktop
    3) this is important but not many ppl know about it- do not have any extra FONTS , keep the only fonts that need. When the windows start it reads all the fonts so if you have a lot it will take long time to boot.
    ---if you can just format your hard drive , and install ONLY programs that you use ---
    or you can go throw registry and eliminate the unnecessary programs from start up and autoexec , system but personally I don't like doing that.
    And here is information from microsft about fast boot.
    http://www.microsoft.com/hwdev/platf...ot/default.asp
    moahdib's Avatar
    Jul 2000
    Post
    don't forget www.98lite.net
    get rid of ie and a whole bunch of other crap that you dont need in a carPC
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
