Really it depends on the amp. Your 2 channel amp may be 2 ohm stereo stable. If so you're golden, you can then parallel both the front and back left speakers and the front and back right speakers giving you a single 2 ohm left speaker load and a 2 ohm right speaker load. If your amp isn't 2 ohm stereo stable, you can run both left speakers in series and both right speakers in series creating an 8 ohm load on each side. This won't hurt the amp any, will usually increase the sound quality as less noise is "transferred" to the speaker, but will decrease the volume quite a bit. The final option is to get a second 2 channel amp and run one amp for the fronts and one amp for the rears. If you do that, you can then make use of surround sound if your audio card supports it.
LinkBack URL
About LinkBacks
