Results 1 to 3 of 3
Thread: Internal Line Driver Question
    May 2003
    I'm putting my pc in the lower hatch part of my camaro. I don't want to run any RCA's to the front of the car, but I need a way to control the volume of the audio and the bass gain. I know I could do the bass gain by using a particular amp or crossover, but the problem is the main volume. I'm assuming that line drivers change the volume by varying the voltage with a potentiometer. If I were to take apart a line driver, or crossover with one built in, could I extend the leads to the pot and remotely mount it up front? Or, does the audio actually travel through the pot, in which case this would add alot of noise to the system? The only other option I've been able to find is the Audio Control Master Volume Control, but frankly I think it's a big waste of money for something as simple as it is.
    Any help would be greatly appreciated.
    ~Troop
    Maximum Bitrate none's Avatar
    Sep 2003
    Quote Originally Posted by Troop
    Yes, it does - noise could be an issue. This might allow remote mounting of the knob: External Digital Volume Control ? but I don't know if he ever finished it. Email him and find out!
    May 2003
    Thanks for the quick reply.
  1. Hooking up amp question REM line
    By Jake in forum General Hardware Discussion
    Last Post: 02-09-2007, 03:19 PM
  2. Replies: 5
    Last Post: 02-02-2004, 10:52 PM
  3. Easy way to mute/unmute line in ?
    By liquid_smoke in forum General Hardware Discussion
    Last Post: 12-31-2003, 02:02 AM
  4. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-04-2003, 12:00 AM
  5. 75 ohm in line resistance
    By hijinks21 in forum LCD/Display
    Last Post: 06-01-2002, 11:26 PM
