heat would consume it until it burst into a spinning disk of fire.
Hi, I've already done a search but it's not pulling up what i want.
Just a quick question. I want to mount my 3.5" WD 80gig HD in the back armrest totally enclosed with foam. Would this create any problems (ie. heat, etc)?? Or do i need to leave it fairly open with adequate ventilation?
Agreed, however you could enclose your hard drive w/ say an 80mm fan and enclose it in foam, however I would not put that in your headrest. I can just see you getting into a head on collision and the doctors pull the HDD platter out of the base of your skull!!! LOLOriginally Posted by binary.h4x
New CarPC on the way again I think. I miss my old one!!!
not that fun.
if you have space enough to fit a cdrom drive in there, a harddrive mounted with air around it(and under) along with circulating air would work
