Results 21 to 30 of 32
Thread: Which antennas for tv cards?
  1. #21
    Low Bitrate belmontboy's Avatar
    Oct 2003
    England (South East)
    and it picks up good quality?
  2. #22
    Jul 2004
    well I tried to find the listed parts at my local radio shack, with no luck I proceeded to the web site but was unsure of exactly what I was looking for. Can someone provide part numbers for those adaptors please?
  3. #23
    Jul 2004
    not to be at all impatient, but anyone on those part numbers
  4. #24
    Variable Bitrate lawrence's Avatar
    Oct 2003
    carol stream illinois
    tried the same amp/ant just to say it didnt work . then tried auto mast still no go tried using coaxle (75 ohm from 300 ohm) adptor still bad ..havent found anything that work very well yet , any other ideas?
  5. #25
    Apr 2003
    Raleigh, NC
    you need the motorla to female bnc, then male bnc to coax.
  6. #26
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    Quote Originally Posted by Ervenwill
    It took me 10 seconds to find these items on radioshack.com...did you even try to look?
    Motorola -> BNC Adaptor
    BNC Female -> Coax Adapter
    -HD
  7. #27
    Jul 2004
    yes I did look as I said above, but without knowing anything about a BNC connector I was a bit in the dark. Radioshacks descriptions leave a lot to be desired
  8. #28
    Jul 2004
    thanks, by the way
  9. #29
    Jun 2002
    Malaysia
    anybody else other than amrit got their TV cards to work with the car antenna? I thought you need a resistance of some kind in the antenna or is that covered in one of the bnc connectors?
  10. #30
    Dec 2003
    i don't know about TV working on a car antenna but i know that it will NOT work for 802.11
    if the antenna does work for TV then you could split the signal with a standard BNC splitter (look for old OLD coax ethernet parts)
    as long as there's no load on the side of the splitter that you're not using (i.e. the deck radio isn't trying to take a signal from the antenna at the same time as the TV tuner) you should be fine..
    also, make sure your grounds are coupled well. the deck radio should be on the same ground as your tv tuner / computer.
    good luck
  1. 5.1 channel Sound cards with onboard toslink (not in the add on case)
    By psyclobe in forum General Hardware Discussion
    Last Post: 06-15-2006, 01:43 AM
  2. Will these PCMCIA -> PCI adapters work with all PC cards?
    By bombboyer in forum General Hardware Discussion
    Last Post: 12-19-2002, 12:46 PM
  3. Need advice for video/input cards
    By Strix in forum LCD/Display
    Last Post: 07-01-2002, 03:27 PM
  4. Securing cards
    By Reaper in forum General Hardware Discussion
    Last Post: 06-26-2002, 05:50 PM
  5. dvd decoder cards (Mpeg2 cards)
    By donalson in forum General Hardware Discussion
    Last Post: 12-19-2000, 12:49 AM
