Results 1 to 2 of 2
Thread: Via Epia 800 Memory issues...
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    Well, I recovered a Epia 800 that I had sold a year back. I had at one time tried a stick of 512mb pc133 and it reported it as a 256mb stick. So I took it out, found a 256mb and a 128mb stick. That was how I sold it. It reported correctly. Now, I got it back, and I want more memory I have 2 sticks of pc133 cl3 256mb. When I install them, bios shows both, but while booting it only "reports" 1 stick, and in XP it shows just 256mb (well, 248, you know what I mean) I would love to update Bios, but I understand flightdeck is gone, and no longer supported? and I cant use a floppy on this classic board. Plus, none of the updates I found say anything about fixing a memory issue. Any other thoughts? Is it the CL3 that is messing me up? Do i just need better quality stuff? Or should I just give up and be happy with 256 its just soooooooo slllllloooooooowwwwww. Thanks in advance!
    Btw, I did and until I and I was left
    2005 Ford Focus ST
    Dec 2003
    Portland, OR
    Well, in case anyone else has this issue in the future, it appears that the chipset is Soooooo old (how old is it? lol) that 512ers arent recognised, and sometimes high density stuff isnt either. Although in reading I have seen no bios flashes that "say" they fix the problem, a post in the Via arena says it will and does correct the issue. Now....how to boot to dos with a non-usb (not supported) writable disk. Grrrr. I wonder....how about Zip? can you use a zip like a floppy? never tried it, never seen one inside...i assume its a ide connector? Any ideas?
    2005 Ford Focus ST
  1. Lilliput 7" VGA and EPIA M9000 issues...
    By heat in forum LCD/Display
    Last Post: 01-15-2004, 04:57 PM
  2. Help with Epia 800 / pw60 / ITPS
    By lalo in forum Power Supplies
    Last Post: 01-04-2004, 03:39 PM
  3. FS: EPIA 800 ITX Motherboard
    By dr1ft in forum Classified Archive
    Last Post: 08-05-2003, 09:57 AM
  4. fuzzy lines on EPIA C3 800 mhz
    By samc in forum LCD/Display
    Last Post: 04-13-2003, 06:26 PM
  5. Epia M and Epia 800 differences
    By wysiwyg in forum General Hardware Discussion
    Last Post: 12-20-2002, 11:50 PM
