Results 1 to 3 of 3
Thread: Controlling relays with Inputs using VB
    Mik
    Mik is offline
    Newbie Mik's Avatar
    Feb 2004
    Leeds, UK
    Have seen a few posts about the relay bards and have one in my room to turn accessories on etc.
    Anybody knows of any input/output boards that I could use to automat things inside my car.
    I would like to automate things,
    I would like inputs for the following,
    Temperature
    Light out side the car
    Left/ Right indicates + reverse light etc.
    I would like to use this information in and automated to control relays etc
    Maximum Bitrate deadweasel's Avatar
    Nov 2003
    Detroit MI
    while all of that is quite possible to do (and indeed has been done a few times and posted here), it's a bit of complexity involved.
    Detecting temperature requires a thermistor (thermal-sensitive resistor), and detecting light will require a photosensor (used for those auto-sensing night lights). Left and right turn signals are a simple matter of looking for voltage on a particular line.
    The problem comes when it comes to converting those voltages (or resistance values) generated by your sources to something the computer can use, and knowing what to do with them from that point. Check out a couple threads that I started regarding this stuff. I learned here that one of the best ways to convert those values (on the computer side) is through the game/MIDI port found with some sound cards.
    You're going to have to do some circuit building, however, for the conversion of the raw voltages/resistance generated by your sensors. This is a grey area for me, but it has been covered here. You might have to search until your mouse is ready to break, but it IS here. Google is also very helpful. I'll post some links here if I can find anything...
    The ALEXIS Project
    MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
    Color Coding :
    DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
    Mik
    Mik is offline
    Newbie Mik's Avatar
    Feb 2004
    Leeds, UK
    thanks deadweasel, have done a bit of gooling but didn't try the search for here. would be great for those links.
    Have found a 240v ac unit but want to find one that will run off 12v dc.
    think the link was on automatedhome.co.uk
  1. developing in VB
    By ShinkunoNamida in forum Software & Software Development
    Last Post: 07-27-2008, 10:13 AM
  2. Controlling MediaPlayer in VB
    By deadweasel in forum Software & Software Development
    Last Post: 12-02-2003, 11:16 PM
  3. high level inputs and low level inputs, what does it mean?
    By TiTUS in forum General Hardware Discussion
    Last Post: 09-28-2003, 09:51 PM
  4. Controlling more than 8 relays on LPT?
    By TintedChrome in forum General Hardware Discussion
    Last Post: 02-12-2003, 08:18 AM
  5. relays & computers
    By marsjell in forum General Hardware Discussion
    Last Post: 05-06-2002, 02:36 PM
