Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 56
Thread: Me experiences with the D-link USB radio
  1. #11
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    I did some more testing and found that the 1/8th line out shielding is not grounded at all.
    I'm gonna bypass running the 1/8th audio line with the USB cable and make a hole in the unit and snake the wire out directly and ground the outer shielding.
    Here's the exposed shielding that goes nowhere. (I think)
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  2. #12
    Jan 2004
    just tacking on here for future reference.
    2002 Subaru WRX - Silver
    -FP18G turbo
    -Walbro fuel pump
    -Modified OEM 840 CC Injectors
    -TurboXS: UTEC, turboback, uppipe, intake
    -Blitz FMIC
    -STI cluster
    -17"x7.5" SSR Competitions
    -Tein Flex coilovers
    -NOS 50 shot
    -2004 rear conversion
  3. #13
    Jan 2002
    Long Island, NY
    Another note.
    I was reading this very helpful thread: http://forum.sounddomain.com/forum/u...c;f=5;t=008251
    I now also think that powering the car antenna amp with the accessory on may also possibly cause noise? How many amps do you think it draws? I was possibly thinking of powering it with the PC power supply.
    Another thing I might do is ground the dlink unit to the grounding distro block.
  4. #14
    Oct 2001
    NYC
    d-link is crapola!
    Guys, guys, guys, don't you search old threads??? I posted numerous times how bad the d-link reception is. Many people have tried putting metal boxes, soldering this, doing that, but why not go ahead and buy the hauphauge????
    Whats so special about the d-link? The wintv is about the same price too!! I have both and I can tell you that the d-links reception sucks ***! Hauphauge is the way to go, Just my opinion from someone who has both.
    http://www.bankingdom.com/carputer/carputer.html
  5. #15
    FLAC Mastero's Avatar
    Aug 2001
    India
    OK friends today i worked on my D-link result was no engine whine, amazing reception as good as a headunit.
    Shall post full details from home at work right now.
    Mastero
  6. #16
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    Quote Originally Posted by Mastero
    Mastero
    /me waits patiently
    *tap* *tap* *tap*
    well...maybe not quite so patiently...
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
  7. #17
    Jan 2002
    Long Island, NY
    Mastero, nice.
    I will be waiting to see what you did.
  8. #18
    Jan 2002
    Long Island, NY
    Quote Originally Posted by bankingdom
    Is the hauppauge USB?
    Also, does Media Engine or Media Car support it?
    BTW, Happauge is 20 mins from my house.
  9. #19
    Aug 2001
    India
    This is what i did soldered 19 gauge copper wire at four coners of the board and soldered them together at the rca pin.
    Cut the ant cable and reverse meaning change the polarity what i have soldered is not ground.
    Ok then i cut the pin for the line in which comes from the D-link usb.
    Took a new stereo pin and soldered the left and right channel and didnt use the ground but used the ground from the Motherboard.
    Meaning a stereo pin has three wires left channel , right channel and common ground. so what i did was gave it the ground from the mobo..
    Try it worked for me
    Cheers
    Mastero
  10. #20
    Jan 2002
    Long Island, NY
    So the blue circled area should be connected to the outer shielding of the antenna wire?
    Cause right now I have it connected to the center pin of the antenna cable and the reception is not that great.
  1. My experiences with various components...
    By Defiler in forum General Hardware Discussion
    Last Post: 01-27-2004, 01:49 PM
  2. USB Radio
    By orangewhip in forum General Hardware Discussion
    Last Post: 03-13-2003, 05:37 AM
  3. WTB: D-Link USB FM radio
    By Stine161 in forum Classified Archive
    Last Post: 11-12-2002, 07:02 AM
  4. Dlink USB Radio Screenshots
    By veedubya in forum General Hardware Discussion
    Last Post: 10-20-2002, 08:38 AM
  5. usb radio
    By shawn in forum General Hardware Discussion
    Last Post: 07-01-2002, 07:04 PM
