Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 39
Thread: Startup thud solution
  1. #11
    Oct 2003
    I guess we'll find out if it works...I just ordered this one:
    http://www.nationalcontrols.com/timer1-9.htm
  2. #12
    Constant Bitrate P4_2.66GHz's Avatar
    Feb 2004
    Here is an easy way to virtually eliminate "thud" from the amp. All that is needed is 2 relays.
    First relay would turn on when the car is on. It can be triggered via cigarette lighter wire.
    First relay would short a positive 12V wire coming out from your PC system to connect the coil of the second relay. Other end of the could would be the PC's power supply ground. The second relay, then would connect the car's 12V (could be from the same cig lighter wire) to the amp.
    Voila, you got yourself a delayed amp turn-on.
  3. #13
    Variable Bitrate Cherub211's Avatar
    Feb 2004
    Chandler, AZ
    Two problems: One: your cigarette lighter works all the time, this is a minor oversight so we'll assume you meant the ACC wire. Second problem, the relays setup as you described arn't delayed at all. They would come on and off as the computer power supply does, not the computer itself.
  4. #14
    Feb 2004
    Quote Originally Posted by Cherub211
    On the cig ligher wire, I did mean ACC. Sorry, never had a domestic vehicle.
    I am using opus power supply, it is 5 sec delayed when starting up. I used to have a "thud" when PC powered up, but used the 2 relays to solve the problem. I assume the thud happens when the PC/Sound adapter is powered up. If that is not the case, (thud happens during boot-up) then my solution would not work. The second relay is triggered by the PC's power supply, at the same time MB, HD and other accessories are powred up and only in the case if the vehicle is in ACC mode.
  5. #15
    Maximum Bitrate albysure's Avatar
    Dec 2000
    pittsfield, ma.
    if you guys searched you woulda found this delay that i use
    http://www.davidnavone.com/detail.asp?PRODUCT_ID=N-66A
    works nice!
  6. #16
    Oct 2003
    Thanks Alby.
    Even after knowing it was you and what the device is I couldn't find the previous reference to it.
    Hopefully I can cancel the order for the one I ordered!
    Cheers,
  7. #17
    Oct 2003
    Just an update. Installed the David Navone on-delay relay (N66A) and it works like a charm. I like the fact that I get a few seconds of silence after the system is on to adjust the volume depending on the passenger.
    Cheers,
  8. #18
    Dec 2000
    pittsfield, ma.
    glad it worked for you
  9. #19
    Variable Bitrate ryuandwings's Avatar
    Nov 2003
    TN
    Quote Originally Posted by Alric
    Cheers,
    That seems to be a simple solution and not that expensive
    One question, how exactly do you connect that?
    It has three wire? Where input coming from and output going to?
    Dec 2000
    pittsfield, ma.
    ground, 12v positive in for the trigger and your output
    what i did was to use the yellow 12v wire from the ps to trigger the delay and wired the output delay side to the amp remote
  1. io.sys at startup?
    By Jamez_Warner in forum MediaCar
    Last Post: 02-23-2004, 05:01 PM
  2. Epia M10000 + PW70a + car startup
    By SuperSonic in forum Power Supplies
    Last Post: 11-27-2003, 02:21 PM
  3. Data logging solution for non OBD2 cars...
    By doig in forum General Hardware Discussion
    Last Post: 11-06-2003, 10:29 AM
  4. startup shutdown etc.
    By marsjell in forum Power Supplies
    Last Post: 06-19-2002, 06:07 PM
  5. Possible solution to the inverter dilemma...
    By gregulator in forum Power Supplies
    Last Post: 08-07-2001, 09:38 AM
