Results 21 to 30 of 39
Thread: Startup thud solution
  1. #21
    Variable Bitrate ryuandwings's Avatar
    Nov 2003
    TN
    I ordered mine, too.
    I hope it works
  2. #22
    Constant Bitrate sanbas's Avatar
    Jul 2004
    united states
    i need suggestions from people who have successfully installed the n66a from navone.
    Mine works half way, when i start the car the delay works fine and there are no pops, thuds, beep, whatever you wanna call em.
    BUT
    when i put the car on just the "acc" or "on" position the pop is there. Then if i start the car from there the delay kicks on and there isnt any audio for 20 secs. or so.
    Not sure why its doing that?
  3. #23
    Jul 2004
    united states
    i know this thread has been dead for a while, but anyone with the n66a working have any inputs?
  4. #24
    Maximum Bitrate d_sellers1's Avatar
    Mar 2002
    Austin, Texas
    Take a look at this thread:
    Turn-on amp POP Stoppers
    Pay attention to post #40 which is my idea utilizing an ELK-960 delay time from Smarthome. Cost is $23.
    Someone commented on 'what about turn-off thud'. Attached is my idea for the wiring diagram but what I just realized is I have it running off the ACC line. If I were to stop and get gas (for example) when I start my car back up, I would have to wait for the delay before the speakers would turn on. Perhaps running it off the +12V from the OPUS to the trigger port and the ACC line to the positive input. (I'll draw a new picture later.)
    EDIT: After looking at this wiring diagram a bit more, I realized that this may cause problems. If I turn off the car (to get gas for example) when I restart the car, I will have to wait for the delay again even if the OPUS keeps the computer on. It would be better to run 12V off the OPUS into the POSITIVE and use no trigger. (The ELK-960 is self-triggering on power up.)
    Derek
    Progress [||-------]
    View my Worklog to see some of my progress.
    Downgraded Progress - Starting with another car... 09/13/06
  5. #25
    Jul 2004
    Those of you using the fake ups trick for a shutdown controller can just hook up a relay to one of the other control signal pins on the same serial port (search for fake ups shutdown controller). The amp comes on when only after the computer starts up... thus no thud. Works fine with hibernation too.
    -momanz
  6. #26
    Variable Bitrate BMVEE's Avatar
    Mar 2005
    Beautiful British Columbia, CANADA.... eh!
    Quote Originally Posted by momanz
    -momanz
    Fake UPS trick?
  7. #27
    Maximum Bitrate albysure's Avatar
    Dec 2000
    pittsfield, ma.
    i have been using this delay circuit from navome for a few years now. i wired the trigger to the 12v(yellow) from the power supply
  8. #28
    Jul 2004
    united states
    what tells the navone n66-a to turn on the delay, i thought it was simply a small current from the turn on wire, but my delay only works if i start the car. It wont work when I put the car on acc. position. ANY EXPLAINATIONS???
    ill try using the 12v molex out of the opus and see if that will work for me, also when doing that will i have to use the black ground from the molex or can i sill use the car chassis ground or does it even matter?
    thanks
  9. #29
    Low Bitrate rmjjensen's Avatar
    Oct 2003
    New Jersey
    How about a capacitor on the remote line in parallel? The cap will act as a short circuit so will charge first and then the voltage will be high enough for the amp to turn on ......bigger the cap bigger the delay ........price? $1
  10. #30
    Jul 2004
    united states
    it cant really be that simple can it? If it is then all 10 million posts about start up thud/pop/beeps need to be deleted and replaced with that one sentence.
    Any particular size cap to start out with?
  1. io.sys at startup?
    By Jamez_Warner in forum MediaCar
    Last Post: 02-23-2004, 05:01 PM
  2. Epia M10000 + PW70a + car startup
    By SuperSonic in forum Power Supplies
    Last Post: 11-27-2003, 02:21 PM
  3. Data logging solution for non OBD2 cars...
    By doig in forum General Hardware Discussion
    Last Post: 11-06-2003, 10:29 AM
  4. startup shutdown etc.
    By marsjell in forum Power Supplies
    Last Post: 06-19-2002, 06:07 PM
  5. Possible solution to the inverter dilemma...
    By gregulator in forum Power Supplies
    Last Post: 08-07-2001, 09:38 AM
