probably the best way is to network the 2 computers using cat. 5 cable with a switch or crossover cable. Just get a few NIC cards and stick em in there. As far as the other problems go, i dont know. try fixing it and see what happens.
I have a bit of a problem, I just got a new home computer and I dont know how to go about tranferring my mp3's to my carputer. When I had my old puter I use to take out the slave and put in my carputer to tranfer the files, but my new puter doesn't have dual drive capabilities. the cd-rom cable is broken on my car puter so I cant use that. I think the paralell port is shot too on my carputer so I cant use a zip drive or a networking program. How should I transfer my files??
Should I buy a cable that supports two hard drives? If so where would I put the hardrive? Is there and easier way to make the transfer?
.:@mÖ§pê®ë:.winamp.win98.pentiumII.10gig
2004 F-150
Shuttle XPC, 80gig HD, Wireless Internet, DVD
"How piMP3d is your ride??"
I agree. You can get 2 10/100 Network cards for $20 each. A piece of Cat 5 cable isn't very expensive either. If you need help making a crossover cable, let me know and I'll post a pin diagram. You can also buy them if you don't have access to a crimper to make one.
As far as your new computer goes, it most likely does support 2 drives. It may not have a second plug on the IDE cable (if not, shame on the manufacturer) but every board I've ever worked with supported 2 drives per channel. If you provide more info and/or pictures on why you don't think that you can put two drives in your new system, perhaps we can help you work through that issue.
$20? bah, cheap ones are about $10
And like meatball said, get a new cable.
I use wireless.
I just upgraded my wireless from some Intel 1Mbps garbage to some real 802.11b 11 Mbps stuff.
High speed wireless kicks ***!
I think this has been covered, but for what it's worth I use Ethernet. I have a jack installed outside my house, and one in the gas filler area of the car. For the price of network cards ($15) it's the only way to go.
