Page 8 of 11 FirstFirst 1234567891011 LastLast
Results 71 to 80 of 107
Thread: Relocating headunit and extending faceplate somewhere else.
  1. #71
    FLAC bosstone74's Avatar
    May 2002
    Japan, Oregon
    Quote Originally Posted by MkRacer220
    Here's the prob....I have all the wires connected (cat5) to the face and HU. None of the wires are touching and they all match up. Everthing on the face (buttons) works, but the volume control. All the buttons light up, the eject button works, but I cannot get the volume control to work. When I hit the reset button and then turn the player on, if i turn the volume control right away I get the volume display to come up for a sec then it goes away, but the volume doesnt change and it wont come back up. I have checked all my solders and they seem good. I cannot figure out why the volume wont work. Any ideas?
    Thanks,
    Tony
    Here is a thought, I have not done this but...
    On my head unit, if I remove the face (controller) there are some switches that are needed to be pushed in for the head unit to operate. And I'm not talking about the where the metal contacts need to meet up. Just a button or a switch...
    take a look
    BossTone74
  2. #72
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Have you traced the connections to make sure you don't have any shorts?
    Also what BossTone74 said maybe true, it could be that the volume is physical, but you should have noticed that.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Button app to Alt-Tab between two programs
  3. #73
    Nov 2004
    Thanks guys, but the volume is built into the circuitry of the board connecting the face to the HU. There is only one button that needs to be pressed in and thats the one that tells the cd player if the face is connected or not.
    I have issolated the problem to just the HU side b/c i took another face (exact same) and hooked it up and the same prob. I checked all wires for shorts and there are none.
    After going back and rechecking the solders I found one to be loose, like the wire is connected to the pin, but the pin can move side to side in the board. I don't think it is made to do that. It may be a loose connection which is giving the volume not enough juice or something.
    I've been working on it for bout 7 hrs straight trying to figure out what is wrong!!
    Tony
  4. #74
    Jan 2002
    Long Island, NY
    Goodluck and let us know if you are able to fix it and identify the problem.
  5. #75
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    I'm going to give this a shot in the Focus, as there is no real place to mount the headunit...
  6. #76
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    Any more recent updates to all these efforts???
  7. #77
    Oct 2004
    NY
    if the volume is controllled by a variable resistor pot in the face theres a chance the long wire run is adding to the resistance enough to affect the volume control....IF this is the case the only solution would be using wire with less resistance on that circuit(if you caneven isolate it) or shorter extention??
  8. #78
    Constant Bitrate munkynpunky's Avatar
    Oct 2005
    Norwich UK
    Hey, I love this idea and I'm gonna deffinately have a go at this, I have a Pioneer P6400R head unit, and I have a spare back since the plastic surround has been ripped off it.. So i have a head unit to test with before i shag my actual stereo..
    Car is Dead, Hand is burnt - Let that be a lesson to me! never open the bonnet when you smell burning.
    http://www.digital-car.co.uk
  9. #79
    Feb 2005
    Atlanta, GA USA
    Ugh, having the worst luck trying this with an Alpine CDA-9855. I must've soldered it 5 times now, and all I get is working buttons, some lights, but no screen. Using Cat-5 like others, and using a volt meter to ensure everything's connected ok, no crossed cables, double-checked wires... so frustrated.
  10. #80
    Feb 2005
    Atlanta, GA USA
    Quote Originally Posted by modUlarBeing
    well i finally got mine working.....
    turns out that the cat5 coupler was KILLING the coltage, there was more than a 90% drop through that coupler!. so now its soldered straight to the HU. I dont plan on using the cd player so its not a big loss. I will post pictures later.
    I'm a little new with the electronics stuff... I'm using a volt meter to measure resistance between the contacts over the wire to ensure each contact is connected. Is this what you're talking about, or are you actually measuring voltage? I'm also using cat-5 couplers, but since the resistance measures the same with them on/off, I didn't think they were affecting anything.
