Results 1 to 8 of 8
Thread: Mini-ITX vs. Micro-ATX question?
    Constant Bitrate P4_2.66GHz's Avatar
    Feb 2004
    Hello Mini-ITX pros.
    Can you tell me if a Mini-ITX board can be mounted in a Micro-ATX case?
    The reason I am asking is I need to know if the Micro-ATX case I have can be used for Mini-ITX applications.
    If there are major differences, what are they? Are the mounting hole locations different?
    TIA
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    yes it can. The common micro-ATX boards have one AGP and three PCI slots as well as some other differences. The mounting hole patern is the same on the mini-ITX just not as many as on the micro-ATX.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Variable Bitrate Cherub211's Avatar
    Feb 2004
    Chandler, AZ
    Yeah, I've looked this up before. The two use the same mounting holes. The only thing that I'm not sure about is which is bigger. But the smaller board will fit in the larger case.
    Feb 2004
    Thanks, guys.
    That's what I thought, just wanted to verify with knowlegeable people.
    Micro-ATX is bigger.
    I am not worried about the expansion cards, just the mounting hole pattern and the connector plate location. Nice to know it will work for Mini-ITX.
    Feb 2004
    Colorado
    why would you want to spend the extra for the motherboard if you aren't going to make a very small computer, microatx stuff can be really cheap. I don't see the point in spending a lot on the motherboard when you don't have to
    Feb 2004
    Quote Originally Posted by forum
    I am not. All of my stuff is Micro-ATX. I wanted to see if it was Mini-ITX compatible.
    Constant Bitrate coffeejolts's Avatar
    Jan 2006
    Duluth, GA
    Ok, reviving a thread from the dead . Is it still true that a mini-itx board's mounting holes will work in a micro-atx case?
    Sounds pointless, right? I want to switch to Mini-ITX for the reduced heat and power requirements, not the size. I still want my PCI video card and sound card to fit in the case. Oh- and I can't see spending over $150 for a tiny case with two pci slots when I can get a micro atx case that will do the trick much cheaper. Has anyone done this who can confirm that the mb holes will line up?
    Constant Bitrate Stealth915's Avatar
    Bay Area, CA
    which Mini-ITX motherboard are you looking to get? Most of the ones I've seen only have 1 PCI slot, so I'm wondering how you're going to be able to use both a PCI video card and a PCI sound card.
  1. getting started....ATX vs ITX etc
    By FiSKARZ in forum Newbie
    Last Post: 01-07-2004, 04:17 AM
  2. newbi 1st question - mini PC
    By dunkonu in forum General Hardware Discussion
    Last Post: 12-24-2003, 03:55 AM
  3. Opus ATX and ITX PSU - Difference?
    By phoTToniq in forum Power Supplies
    Last Post: 09-22-2003, 04:21 AM
  4. What is the best Micro ATX (ITX) motherboard?
    By CA 3000GT in forum General Hardware Discussion
    Last Post: 01-27-2003, 03:04 PM
  5. micro / mini atx system w/ LCD and all the goodies
    By gizmomkr in forum Classified Archive
    Last Post: 05-09-2001, 04:08 PM
