Results 1 to 4 of 4
Thread: standby power drain problem
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    tossing around the problem regarding the computer staying in standy while the car is off
    it seems to be no problem if you drive your car every 1-2 days but at times i dont drive my car for longer than that
    i thought maybe i could rely on my opus psu to release power to the system once the battery dipped below 11v but i talked to someone from opus and they stated that this feature only works when the computer is in the on state
    very dissapointing
    any ideas regarding this problem?
    i could just turn off the computer but..meh
    Newbie neutral's Avatar
    Nov 2003
    South East PA
    Hibranate instead of stand-by? Worth a shot.
    Maximum Bitrate none's Avatar
    Sep 2003
    I think if you don't drive your car for long periods of time, you should give up on the hope of using standby. As neutral said, hibernate is a good alternative.
    You could also try some type of standalone low-voltage cutoff connected in series before the Opus, but you will have to sit through a longer full bootup whenever it gets tripped.
    edit: I just noticed where you live aoLhaTer, and I am jealous! MB is one of my favorite places in the world!
    Mar 2003
    Rohnert Park, CA
    hibernate takes just about as long to come up as powering down and up does
    i wish opus put in functionality to preserve battery even when the comp was in standby
    and ya, manhattan beach owns
  1. m10000 won't power up
    By swzine in forum General Hardware Discussion
    Last Post: 11-23-2003, 03:49 PM
  2. Problem testing VIA EPIA w/standard atx power supply
    By khufumen in forum Power Supplies
    Last Post: 11-15-2003, 03:22 AM
  3. getting an odd motherboard to power on
    By karmann in forum Power Supplies
    Last Post: 11-28-2001, 06:27 PM
  4. Average power breakdowns
    By Telek in forum Power Supplies
    Last Post: 11-23-2001, 08:07 AM
  5. 300 watt power inverter problems
    By DaPyro in forum General Hardware Discussion
    Last Post: 03-10-2000, 03:56 PM
